Home > Technical > Cold left leg when driving - Could it be Cool Box ?
carlos50
Hi all
Having had my S/C for a few weeks now ive definitely noticed that my left leg and hip area are cold when driving. I have the cool box option and wonder if its linked to that ?. My last car was a Mercedes SL which had the same sort of thing and i experienced the same cold feeling with that car.
Has anyone had this issue ?.
There was a fix with the SL that involved adding insulation underneath the console & sealing the trim panels so that cold air couldn't escape. It was an owners forum fix rather than MB and i wonder if others on here can offer some information similar to that ?.
Can anyone help ?.
Thanks
Carl
Post #278887 Thu Oct 28 2010 6:56pm
Tim in Scotland
Have you tried switching off the cold box to see if that makes any difference? Also is the ball warmer vent under the steering column open or closed? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #278897 Thu Oct 28 2010 8:41pm
carlos50
Hi Tim
I should have been more specific, the cool box was off. I tried turning it on but didn't notice a big difference in the cold leg feeling.
The ball warmer vent under the steering wheel has a broken slat but i dont have air coming through the centre vents, only the top & bottom options. If i put my hand on the ball warmer its not cold by any means.
The cold feeling is round the back of my leg / hip but i dont feel any obvious cold air coming up from the seat area but after a 30 minute drive i have an aching leg from it. My Mercedes did the same thing with a cool box fitted in the centre console Big Cry
Any ideas ?.
Post #278898 Thu Oct 28 2010 8:55pm
If your having the same cold feeling with both cars......
Could it be you Question as in bad circulation in the hip area Laughing
Or a lose connection to The rear vents
Post #278899 Thu Oct 28 2010 8:59pm
carlos50
I drive other cars from time to time which dont have cool boxes in the centre consoles and dont get the cold feeling.
Perhaps it is a bit of me and a bit of the car Sad
I would like to know if anyone else has had this though.
Post #278900 Thu Oct 28 2010 9:03pm
Rudskibaliblu
England 2012 Range Rover Sport SDV6 HSE Orkney Grey
I get it, its called sciatica. Whistle Now gone Orkney grey SDV6 HSE with body style kit contrast stitch ebony leather, privacy, black piano, 22" Lowenharts for summer, 20" with Leon LTZ for winter.
Here 110 black edition defender.
Post #278923 Fri Oct 29 2010 7:38am
carlos50
I don't seem to have the same problem with other cars so there must be a cold area in the RRS as their was in the Merc SL ?.
Its uncomfortable rather than an obvious draught of cold air but its something id like to fix if i can.
Post #278924 Fri Oct 29 2010 7:56am
Have you checked the vent beneath the steering wheel that blasts air into your groin area? 2005 Zambezi TDV6 - Gone but not forgotten
Post #278928 Fri Oct 29 2010 9:45am
carlos50
Yeah, its from the back area of the seat / console not the front.
Post #278932 Fri Oct 29 2010 10:07am
is there any air vents for rear passengers in the centre console? possible feed pipe for them maybe loose or possible the rear passenger foot blower under your seat
If you have the heat turned up, does your ass become warm, maybe a way of telling if its a loose fitting Idea
Post #278934 Fri Oct 29 2010 10:23am
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
I believe the problem could be absolutely anywhere in your car because of the way the air circulates around. I might be wrong. Obviously, the best way to find out is to go through the entire inside and see if you can identify any air leaks... you should not have much problems in finding it as you say its only 30 min and your leg is real soar, so the leak must be pretty bad. Vadim A.
Post #279042 Sat Oct 30 2010 4:34am
