![]() | Home > General > 4 Wheel Alignment Advice Request |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293 ![]() ![]() |
All,
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
I went to a wheel specialist in London... 4 wheels for £75 + VAT...guess that close the subject...
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
paulo they are taking the ![]() http://www.alignmycar.com/ This will give you the nearest garage to you with Hunter KDS machine which is what Land Rover should be using. I had mine done on my M3 in perth for £50, you get a full print out befopre and after etc. |
So there's no camber settings etc etc that a non LR dealer won't be aware of? 2022 P440e AB |
Paulo that is the system land rover will be using mate or SHOULD be using. It gives accurate readings on your suspension geometry, it is know in the track car world etc as GEO. The technician gets a reading of your current settings and then makes the necessary adjustments according to the readings. You receive a printout very similar to the 4x4 info display on your RR but it gives your settings and green squares for ok. I used to have a file for my M3 but i cannot find it to post the KDS print out. Where about are you in Scotland? You will end up with this
The red shows where the adjustment is needed. This is not my car but an example i found on google just to illustrate what i was talking about. |
8 CDC Member Since: 21 Apr 2010 Location: Sth Lanarkshire Posts: 59 ![]() ![]() ![]() |
Chris mc is spot on!!
Thanks chaps.
