![]() | Home > General > Suspension totally failing - help |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
Must have been a lot of diagnostic time. The cost of OEM Compressors are about 800 bucks, i just had one fitted by a LR specialist not a dealer, as the specialist knows the marque, i have no faith the LR dealer franchise do.. Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Damn....if Ritter couldn't fix it....must have been something very obscure and broken. Can't think of a logical reason why a new compressor would burn out so quickly unless it was faulty when supplied or it was having to work constantly. Is it all fixed yet? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
standard dealer approach... which is fine when it is in warranty, but not when it is out. a long shot could be to call Ayers Automotive in Brookvale, NSW http://www.aauto.com.au/ see if they have any pointers that can help... i use them all the time, far better than the dealerships.. Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
RRS_bunny Member Since: 24 Jun 2008 Location: Australia Posts: 47 ![]() ![]() |
Its back at the dealer, and we have the awesome volvo back again. Conveniently there are no RR loan cars available.
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
I had the same issue with KM's and petrol for test usage!
They have someone fancy from LR involved - it isn't helping, they are still unable to work it out. |
I'm guessing its him then, he was involved in my issues when after 7 months they were still occurring?
Me too. Still really annoyed about paying for a second compressor in 2 weeks and still not having a functional car. Apparently the first new one "burned out" in only 2 weeks, so I'm guessing the second new one has now also burned out as its been 2 weeks since it was fitted, and the problem is not resolved. |
Am I missing something, but don't you get a 12 month warranty on any original part replaced by a dealer?
All LR parts are warrantied for 1 year. If a part was replaced under warranty then it is 1 year or until the vehicle warranty expires, whichever is first.
@Bobby |
redrover Member Since: 22 Jun 2007 Location: Sydney Posts: 94 ![]() ![]() ![]() |
I am amazed at the poor level of diagnostics these days. The compressor is been driven by computers that are behaving erratically, possibly causing the compressor to fail. An erratic computer can caused by a number of things, but mechanical issues such as a poor earth or dry solder joint are common problems.
Yes they did update the software. Unfortunately it was Ritter than replaced the compressor the first time. Have to talk to them about a refund. I would have thought that when a fault occurs, the fault code would be enough information to isolate the problem? I work in IT and the whole job is basically troubleshooting stuff that is going wrong, or will go wrong. It seriously shouldn't take this long to isolate the issue in the car..... Seems like whoever programmed\engineered the fault codes\comms system needs a good kick up the rear. |
Agreed, the software development is clearly shocking.. Given that the dealers seem pretty much trained to only look at the what error codes are reported and replace offending part, the software needs to pretty much trap and report any error as an error code.... The software error handling seems to miss trapping and reporting a lot of errors, and then you get the dealer response that there was no error reported and they can't find what is wrong... even when the end results are noticeable as in your case... |
