![]() | Home > Technical > PTI/Bluetooth problems... |
| carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402
Hi Ali
| kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382
Hi Carl
I'm considering pulling the fuse in the glovebook to hopefully "reset" the bluetooth and see if that helps.
| SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 541
Hi Kismet110,
Right, tried it with engine running, no luck. Took out the fuse (Number 52, 5 Amp) & replaced it with a new one, when I turned the car on & pressed the 'phone button on the dash it flashed "Phone Removed" for a few seconds then went back to "No Phone Fitted" |
I have done the same and no luck either.
Pairing isn't normally a pain, in my 2007MY very occasionally the phone wouldn't pair, the problem was frequently getting the phone to stop being paired to the car after I had got out of it at home, even with the ignition turned off sometimes it would stay paired to the car for ages afterward!
Hi Tim
I asked my local LR dealer today and they said "bring it in we can check functionality for £60".
Have you been to the dealer yet kismet110 ?. |
My phone is set to handsfree and nothing.
They are also available on eBay, but you have to be careful to get the correct module, there are two types 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| All times are GMT |
2005 RRS HSE 2.7 TDV6
