![]() | Home > Tips & Tricks > Pairing Blackberry Bold 9000 with 2005 RRS S/C |
Have you tried pairing any other brand of mobile phone too? Also are you using the 2121 password code? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402 ![]() ![]() ![]() |
Hi Tim
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
On my 9000 Discoverable is set to Yes. Then I select Add Device. Then select Search. In parallel th car has to be in pairing mode.
Hi ilard
It sounds like, if you have not been able to pair another make of phone to it as well, that your Bluetooth hardware has either got a lead disconnected or is broken. If your car has any warranty from the supplying garage then take it back to them and make them fix it under the warranty. It appears that it has not been working since you bought the car. Do you know if your car had an after-market Rear Seat Entertainment system fitted that may have been removed before you bought it? Removal by an "amatuer" may have accidentally disconnected the the power to the B/T.
Hi Tim
Your phone will show it is paired to "Land Rover" and if you press the green phone button on the steering wheel or the phone button on the radio it should say "Bluetooth" on the radio display if I recall - I sold my RRSport 2 months ago and now have a 2010MY Full Fat Range Rover which has a different system. I think you may have to bite the bullet and take it into you local LR dealership to get it checked out. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
