| RRSPORT.CO.UK | ||
|  | Home > General > TRANSMISSION FAILURE MESSAGE = any clues ? |
| Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208    | How is the battery?  I believe these messages start appearing when the battery is not as fully charged as it could be, ie, colder weather   | ||
|  Sun Sep 26 2010 9:03pm |
| ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163    | Check your brake light bulbs are working ok. | ||
|  Sun Sep 26 2010 10:05pm |
| nic Member Since: 04 Sep 2010 Location: london Posts: 20      | I shall check away .. love the car but it does seem to have more than a few problems in general !!  | ||
|  Mon Sep 27 2010 8:12am |
| ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704      | Brake pedal sensor was causing it on mine. It was sending a faulty signal to everything which made the car shut everything down. Guys at lookers had it sorted asap. WINNER - 2008 Best All New Photograph
|  Mon Sep 27 2010 10:03am |
| GIB 984 Member Since: 31 Jul 2007 Location: Midlands Posts: 77      | Sounds similar to my problems - I swapped the bulb (have had 2 blow) but problems continue and tonight I was told that my problem bulb is burning too bright. When I got home and turned off and pulled the key out, my satnav, message panel and hand brake signal all stayed on. Turned the f****ing thing on and off again a couple of times but they all stayed on until finally I only have the hand brake light still on. Have come in before I put the hammer on it!
|  Tue Sep 28 2010 8:26pm |
| GIB 984 Member Since: 31 Jul 2007 Location: Midlands Posts: 77      | Mechnaics found that one of the EGR valves was stuck open - both were full of   | ||
|  Wed Sep 29 2010 3:53pm |
| Posting Rules
 , or  when it is old and about to fail, or if you have left something switched on too long without the engine running. The low coolant message usually means the float in the coolant bottle has absorbed coolant and sunk,(due to the excellent choice of materials by Land Rover
   ) giving you a  false indication (unless you actually have lost coolant of course), new coolant bottle / sensor should fix that.
 so I had them blanked off. Picked it up about an hour ago and it drives better than it has ever done!
