![]() | Home > Technical > Steering Off Centre |
Alignment? Malaysia Boleh!
JonnyDangerous Member Since: 09 Nov 2009 Location: Reading Posts: 57 ![]() ![]() ![]() |
I have this exact same problem on my MY10. Still on original tyres. Car going into LR next friday to be checked. |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
But how can the alignment be out just by changing the tyres |
Alignment checked and fine, incorrect pressures would appear to have been the cause |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
just to follow up on that...
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Isn't it the case that they need to centre the steering wheel and then correct the alignment? |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
I had this issue for many months between about Mar 09 and Sept/Oct 09... The dealer and even land Rover kept claiming it was road camber. They eventually fixed it, but when they did they claimed there was no issue found! So I therefore have no idea what they did to correct the issue. |
I would hope that the tech know what he was doing but will double check that!!!
You're right....I now remember your posts abt it... shame they didn't told you what they've fixed Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
MJW267 Member Since: 20 Sep 2010 Location: Bishop's Stortford Posts: 6 ![]() |
had full wheel alignment done and steering wheel has been off centre ever since - not by much but trye pressures make no difference. |
After completing the four-wheel alignment, if the steering wheel is more than three degrees from the straight ahead position, remove the steering wheel and reposition on the nearest spline to the straight ahead position. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
RichardM Member Since: 25 Sep 2009 Location: Herts Posts: 745 ![]() ![]() |
Noticed this on mine too today. Will check the pressures asap in case it is that. Strange I hadn't noticed it but before now I keep looking at it! WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
