![]() | Home > Maintenance & Modifications > Nitrogen tyre inflation?? |
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 ![]() ![]() ![]() |
Hi Tim, the advantage is that the tire pressure remains constant all the time compared to air (it doesn´t matter if it is 30C outside or 10C). Also they say that you tires will last longer and that you use less fuel because of that. The other advantage is that if you have a puncture the tire is less likely to blowout 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
Thanks Markos, I've googled it and The AA and several other tyre specialists say it's a load of rubbish unless you are inflating F1 tyres or airplane tyres, but of course the company that sells the nitrogen inflation machines say it's the greatest thing since sliced bread and will save you lots of money in worn tyres and excessive use of fuel (what a surprise!)
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
Tim
Generally speaking though Leeds not too many cars get up to 39000ft and down to -45c outside air temperature. I appreciate the safety value of Nitrogen filled tyres for aircraft. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
i thought it was something to do with them not losing pressure as much
NP you still have to check your tyres even with Nitrogen in them and if you have had nitrogen filling done then you cannot use an airline to add air as you are defeating the reason for putting nitrogen in................... you have to keep returning to a forecourt with a nitrogen line. Adding nitrogen will not slow down any deflation if you get a puncture - it's only the molecules that are larger then air molecules and I doubt anybody on here has such good eyesight they can see molecules! Nitrogen filled tyres will still eventually go flat if you leave them lon enough, but I would like to think that members here are of sufficient education that they check their tyres at least once every couple of weeks to see they are at the right pressure. You will not notice any difference in 2 weeks between leakage from an air filled tyre and a nitrogen tyre unless there is a puncture, and then both would be flat! OK so i's a £1 a tyre, but I think that £1 is better in my pocket than in a tyre dealers pocket................ 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I think they say you can use normal air to top up as it will not be 100% nitrogen in the tyre anyway
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
I personally never check my tyre pressure |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 ![]() ![]() |
I personally like to fill my tyres up with a 78% concentration of nitrogen to be on the safe side!
Daz I actually have a source who can get you a PRE-MIXED gas which is made up of 78% nitrogen. Obviously this is rare so expensive. Let me know how much you want. |
Aircraft tires are designed to withstand extremely heavy loads for short durations. The number of tires required for aircraft increases with the weight of the plane (because the weight of the airplane is distributed better). Aircraft tire tread patterns are designed to facilitate stability in high crosswind conditions, to channel water away to prevent hydroplaning, and for braking effect. Aircraft tires are usually inflated with nitrogen or helium in order to minimize expansion and contraction from extreme changes in ambient temperature and pressure experienced during flight. Dry nitrogen expands at the same rate as other dry atmospheric gases, but common compressed air sources may contain moisture, which increases the expansion rate with temperature. Aircraft tires generally operate at high pressures, up to 200 psi (13.8 bar) for airliners, and even higher for business jets. Tests of airline aircraft tires have shown that they are able to sustain pressures of maximum 800 psi (55.2 bar) before bursting. During the test the tires have to be filled with water, instead of helium or nitrogen which is the common content of aircraft tires, to prevent the test room being blown apart by the energy when the tire bursts.
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 ![]() ![]() ![]() |
I can confirm it is of very limited benefit for standard car applications Tim. I speak in this instance as an aircraft engineer of long, very long, experience.
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
http://www.youtube.com/watch?v=oyzg6y7fqGQ ![]() I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
