![]() | Home > Technical > Battery or is it a Major problem and time to get rid ? |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
In the last two days the vehicle has displayed in the message centre " Suspension Fault, Normal Ride Height only" plus the amber warning light, and today it has now added to the list "Special Programmes not available" and no lights are on in the TR console, not even the standard on-road is lit up |
Zilch, is it still the original battery? If so then it may be time to get a new battery or get the alternator checked that it is charging. Also select 4x4 info on the nav screen and check that all the suspension sensors are working 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I had these symptoms and it was the air compressor leaking... |
Tim no its a second battery, original was replaced about 14 months ago Will check out the fuses and see if that helps Thanks for the info Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
td6006 Member Since: 20 Feb 2010 Location: wales Posts: 45 ![]() ![]() |
Hi Zilch had all same symptoms on mine it was air suspension compressor gone, had it changed along with fuse been fine eversince. |
thanks for all the tips
As per other note, the compressor had failed, the specialists could not get hold of LR original parts, Allianz are approving new after market compressors... 3 Sports this week referred to the LR Specialist, 1 pushed back to LR dealership, the poor sod as a 10 day wait as it is under LR manufacturer warranty and needs genuine LR parts, i suspect they will fail before the after market ones based on the build quality i have experienced with LR |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942 ![]() ![]() ![]() |
4 years and now it needs a replacement compressor? After all the Stockton Beach and offloading you have done?
BK it averages about 4 - 5 off roads a year, nothing taxing or hard..some no more than your Vineyard runs ![]() it has had since new: New Steering rack Brake Servo contamination / servo failure Brake recall and modification Recovered due to sensor failure after Engine Management upgrade New transfer box New Control arm bushes and ball joints New Front Diff New Air Compressor New Wiring loom and New Radio - ![]() it can go on and on, but will keep it to the big ticket items, the list is a bit longer than you think ![]() EDIT: REMOVED DISPARING REMARKS ![]() PS BKHK, your right, time to throw off the yoke, go with the local flow and order a Toyo or a Nissan ![]() MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre Last edited by Zilch on Wed Aug 04 2010 12:38am. Edited 1 time in total |
Yep, it looks like its had a few parts over its lifetime, fair point.
Would go new again if i got another, but will wait for the bugs to be ironed out on the MY10, maybe a MY12, as for a FFRR, not quite ready for the pipe and slippers ![]() As for a Toyo, i was so p155ed off Sunday night after nursing it back from QLD for 23 hours, that i checked out the prices on a new Prado, the Kakadu which is basically same spec as the Sport, is the same price on the road as a 3.0 V6 sport ![]() It will stay for now.. Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
But imagine having to look at a Prado every day.....it isn't a good looking vehicle and doesn't drive as nicely as the RRS, it's much more truck like on the road. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
