![]() | Home > Technical > Headlight Unit Removal |
Details of how should be in your manual. 2005 Zambezi TDV6 - Gone but not forgotten
gaz3014 Member Since: 02 Jan 2010 Location: Northants Posts: 69 ![]() ![]() |
Was hoping someone might have some top tips, I can use along with the manual!! Why wait till tomorrow, when today is already here!
If they are the same as the older lights (>2009) there is a tab / clip each side which pulls up and the headlight just pops out. Easy! Even I have done it!! |
When I had the LEDs done on my 2007 RRS the company that did the conversion told me that it was very easy to change them, just two clips to undo and they pop out BUT you must make sure that you have the keys out of the ignition as the lamps electrical ballast starts charging up as soon as they key is put into the ignition and there are a lot of volts and amps running through the lights units, so take care if you are going to remove the units yourself. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Brilliant!!!! thanks very much guys. |
rrs2010 Member Since: 10 Feb 2010 Location: Leicestershire. Posts: 173 ![]() ![]() ![]() |
Remove the front grill first |
