Home > For Sale & Wanted > Wanted Logic 7 Amp/speakers
PapaBear
2008 Range Rover Sport TDV6 HSE Zermatt Silver
Looking to upgrade from Hi-Ice to Logic 7, any help, tips, parts much appreciated!
Post #260522 Mon Mar 22 2010 8:01pm
Bob
2006 Range Rover Sport Supercharged Zermatt Silver
Looking at the Logic7, it has a different sub, and an extra 2 speakers in the roof (and one in the middle of the dash?). With all of the associated amplification and speakers (14 speakers, 12 channel amp), as well as the head unit, it might be simpler (and cheaper) just to swap the car out for one that already had Logic7 installed.
My main dealer told me that it couldn't be done.
Bob.
Post #260608 Tue Mar 23 2010 2:51pm
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
http://cgi.ebay.co.uk/Harman-Kardon-LOGIC-...23061eabab SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #260610 Tue Mar 23 2010 3:41pm
PapaBear
Thanks Bob, appreciate the input!
From what I know, which isn't much as yet!, the head unit is the same between Harman Kardon Hi-Ice as fitted to my HSE, and the Logic7 Head unit. I think the base head unit is different and doesn't use the MOST bus system, so that would be an expensive exercise. With the exception of the roof-mounted mid range speakers all the grilles are in place to accept the additional Logic7 units, so apart from a bit of rewiring it should be a straightforward swap - famous last words! I'll be stripping out the doors to whack in a couple of layers of bitumen-based sound damping anyway, so an ideal opportunity for a speaker upgrade.
Thanks Skywalker for the ebay link!
All the best from the soggy south west........
Post #260614 Tue Mar 23 2010 4:08pm
Bob
Re: Wanted Logic 7 Amp/speakers
Keep us updated, I'll be very interested to see how you get on. I know the subwoofer on the Logic7 is active, but on the "normal" unit it's passive. I don't know if it's actually the same drive unit.
I must say though, the Logic7 system is truly awesome........the best sounding car system I've heard!
Bob.
Post #260618 Tue Mar 23 2010 4:21pm
Pelyma
Have a look on Disco 3 they have done this upgrade on there. Porsche Cayenne S Diesel 66 Plate
Post #260621 Tue Mar 23 2010 4:39pm
kluklut
United Kingdom 2007 Range Rover Sport TDV6 HSE Adriatic Blue
To be honest, I didnt find significant improvements between a TDV8 Logic7 system I heard with a regular HK in my HSE. You'd be better spending the dosh on speaker or sound upgrades... I'm not sure the expense, rewiring and all your good work will bring the results you want. Unless you're really keen on watching movies in the car... thats the only time (I've been told) when the logic 7 really shines... Also, If the head unit doesn't have the Logic7 option, would a simple amp upgrade also upgrade the headunit to display logic7 options???
Post #260758 Wed Mar 24 2010 12:02pm
hario69
I have the logic 7 already but a couple of the speakers are crackling so may be blown
Id rather not replace the whole amp/wiring, but just change the speakers for better, higher watt versions
Anybody know the specs of the Logic 7 speaker system and whether I can just buy the same size aftermarket speakers and swap them over?
Thanks
Paul
Post #270229 Fri Jul 02 2010 5:20pm
