![]() | Home > Technical > Left rear door will not unlock |
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 ![]() ![]() ![]() |
Did you have the child lock on? Cause thats why it would not open from inside. Can you hear the motor working on the door or not? |
accyis Member Since: 06 Feb 2010 Location: Lancashire Posts: 109 ![]() ![]() ![]() |
Hi. Sit in the car and try and operate the door latch as you normally would. Once you have pulled the door latch outwards try pressing the unlock button on your key fob. This happened on mine with the same door and it would only open this way by me assisting the latch. It appeared to lack the power to operate on its own, ie without help. I suspected possibly a weak solenoid but they just replaced the complete latch under warrenty. Try and see if this opens your door for starters. Hope this helps. |
NickM Member Since: 15 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
I have same issue on rear drivers door but can never find the child lock. Point me in the right direction pleaser...thanks |
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 ![]() ![]() ![]() |
Rear drivers door ![]() ![]() ![]() Jeep 4.0 High Output XJ 94 6" teraflex lift, c/w rear coils, 9500lb winch, 35" TSL super swamper boggers, safari snorkel, custom made bumpers, tom woods custom double cardon driveshaft, twin electric fans. Don't follow it..............you wont make it. The first 4 x 4 by far. |
RRSTDV8DK Member Since: 26 Mar 2007 Location: cph Posts: 67 ![]() ![]() ![]() |
Hi sweetafton - Child lock off, actually it has never been on. It sounds like it unlocks, but no.
it does not sound like the motor is working. When inside the car and opening via the door latch and then the key fob it works. But still no remote lock. Is the only solution to change the whole lock? RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass |
Thats what they changed on ours under warranty. They probably throw parts at it. |
Ok - anybody got a manual on how to change the lock and which part numbers you need? RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
Had the same problem Luckily opened from inside, not had problem since. |
It's a miracle. I had no time to sort the problem before the summer and now it works all fine again.
