![]() | Home > Off Topic > Number Plate |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
I bought a replacement number plate and it came undrilled but with adhesive pads......I used these but in the heat it keeps coming loose!
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Cant you just drill holes in the one youve got?
and if you have your old plate use it as a template. 2005 Zambezi TDV6 - Gone but not forgotten
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Or get some better pads - and use more of them |
RichardM Member Since: 25 Sep 2009 Location: Herts Posts: 745 ![]() ![]() |
Don't worry summer will be over next week and it will be much cooler till next year! |
4wheeldriver Member Since: 13 May 2009 Location: Aberdeen Posts: 955 ![]() ![]() ![]() |
if you're drilling it yourself put the wood underneath it and put black insulation tape on the points to drill. Saves the bit skidding and prevents the plate cracking!! |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
what they say ^^^ |
I believe they don't come pre-drilled as each car/model has different hle positioning. ISTBC 2005 Zambezi TDV6 - Gone but not forgotten
The local place up here that I get mine from wont predrill them for you either to do with the holes all being in different places depending on the car. Nip up here with it Johnny and I'll drill it for you!!! |
purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990 ![]() ![]() |
take care cos the plastic can quite badly crack around the hole when drilling purple people eater
I have a solution.......I shall do a colour scan of my number plate, print it on adhevise paper and just stick it on! |
