![]() | Home > General > Vibration in steering wheel |
| yogibear Member Since: 28 Nov 2009 Location: wolverhampton Posts: 43
Need your help please
i know how you feel |
| Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187
Mandanz I also had a problem like that on my car(the steering wheel was shaking like crazy at speeds around 60-75 mph - the wheels were balanced ok) and at the end the problem was in tires. Sometimes the tires can get displaced in the rim. What they have to do is take the wheels off deflate the tire and turn the tire 180 degrees inside of the rim. Than they have to inflate the tire to 5 bars (normal is 2,5 bars) and than deflate it again and inflate it to the normal tire pressure. I had that problem 1 month ago and since that I already did 1500km and the RRS drives perfectly. Good luck 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
| mrloudly Member Since: 30 Dec 2009 Location: Naseby Northants Posts: 48 |
"Following the road test it was concluded that the above is characteristic of this model "
| Garrie2283 Member Since: 01 Jul 2009 Location: coal point New South Wales Posts: 14
Hi Yogibear, I have a 2006 Range Rover Sport and when I first purchased it (almost new) I also noticed what I would call a resonance through the steering wheel at the same revs whilst under slight load. Although it initially annoyed me I felt it may improve with age as mountings soften. By the end of the warranty period (3 years in Australia) I decided to have a chat with my Dealer to see if anything constructive could be done. . They asked me to bring it in which I did and left it for one week. They certainly tried very hard as when I picked the car up the repair order listed the work that had been done and numerous suspension, steering and other rubber bushes had been changed. Unfortunately, this did not cure it completely so I have lived with it and now it has done 90,000km and either I have become accustomed to it or it has improved, whichever it is I am quite happy to live with this considering how brilliant this car has been.
| rrspoland Member Since: 04 Dec 2008 Location: Warsaw Posts: 123
does it happen while driving or in parking? if while driving have you guys checked your wheels (alloys to be more precise)? maybe the wheels are bend. I had this problem, but once I fixed the wheels it is all gone now. My name: Patryk
| redrover Member Since: 22 Jun 2007 Location: Sydney Posts: 94
I have exactly the same issue and response from Landrover (characteristic of the lock up clutches in the torque converter). It is definitely a resonance and seems to be only the TDV6. Mine seems to be getting a little worse and I managed to get the service guy to notice it just before it ran out of warranty in case it becomes a fault.
| gseum Member Since: 15 Feb 2010 Location: Germany Posts: 32
Does anoyone know, if these vibrations are also "characteric" for the new 3.0 TDV6?
| will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377
"characteristic of this model"
