![]() | Home > Technical > Brake Issues |
| viper Member Since: 21 Apr 2007 Location: chester le street Posts: 857
took mt my2010 tdv6 in yesterday to get the gearbox fault sorted and said it has a shake through the steering wheel got a call back to say the brake disks are warped so hope to pick car back up today car was new in november now has 3k on clock .
| SilverspeedRRS Member Since: 29 Jun 2007 Location: Leicestershire Posts: 95
Are the discs a warranty item? |
| NightFox Member Since: 02 Mar 2010 Location: North Shropshire Posts: 381
Warranty wouldn't cover normal wear of brake disks, but after only 6000 miles then should be covered as that is excessive wear. Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Had LR assist out as the noise was so bad. Disintigrated brake shoe and broken pad clip grinding against the disc. LR assist guy reckons the hub is so discoloured because I have been generating so much heat. Booked in for next week for dealer to sort. Never had anything like this on my old RRS or my Jag. Believes it may be due to electric handbrake issue. Makes a change for it to be hardware not sofware issues !! |
silver they changed the discs under warranty no problem car has only covered 3k but as for the gearbox fault warning they updated the software and gave me the complimentary 2 bottles of wine but guess what took car out yesterday and warning came on again |
Got car back last night replaced rear hub and brake shoes. All ok now and at least no 'rusty' hub to look at in the short term. Sorry to hear gearbox warning light has come back on. Mine has not re-appeared since they updated a part near the gear lever ( it wasn't just a software issue I believe). Good luck |
silver well they took car back last week and it was as you said a switch in the gear selector only took them 4 days to fix |
| All times are GMT |
Range Rover Sport TDV6 3.0
