![]() | Home > Technical > Dead battery...how to put the vehicle in neutral???? HELP |
| Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586
foot on brake, key turned in ignition should do it.......but Im not sure as Ive never had a dead battery... |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104
That shouldn't work if battery completely dead as the solenoid on the brake pedal will need power to unlock the gear selector |
| Frosty_Power Member Since: 02 Oct 2008 Location: Calgary Posts: 93
Nope, doesn't work. Tried several times. |
If this is the case, I imagine I'm screwed and have to purchase a battery charger |
| Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435
mine goes flat after a short time too, had too many flat battries in the 2.5 years of ownership |
| disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147
There is an emergency release procedure. I know how it's done in a D3, but for the RRS, if it's not outlined in the manual, try the GTR online.
I thought about an emergency release - there is for the EPB but i cannot recall hearing of one for gear select.....
| Alex Member Since: 06 Mar 2008 Location: Luxembourg Posts: 3
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
As MAW said, EPB emergency there is but I too have not heard of emergency gear select release! Interesting.
Good advice. Or you could just carry the jump battery to the car and jump start with it. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
In the D3, you remove the trim panel behind the EPB switch. The 'interlock' override switch is a small white tab that you can lift up and then move the gear lever out of park. Cheers, Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers 2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT |
| Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275
First make sure the car cannot move if the gear lever is taken out of Park or the EPB accidently released (by chocking the wheels if necessary).
Nice one |
