Home > General > HELP - Door Side Skirting/Trim
KR1005
Hong Kong 2006 Range Rover Sport 4.4 V8 HSE Zermatt Silver
Help needed!!! Does anyone know how to remove the door side skirtings on a RRS 2006?
Post #264967 Tue May 04 2010 2:14am
roverGP
United States 2006 Range Rover Sport Supercharged Java Black
There's 2 screws on the small skirt on the front fender then on the front door you just pull from the bottom, there's little buttons that unclip when you pull it off. You may need to replace some of them depending if they break. You can pick up extras at your local dealership. then on the rear doors you do the same just pull.
Post #264970 Tue May 04 2010 3:51am
KR1005
That's very helpful many thanks will try.
Post #264971 Tue May 04 2010 4:13am
