| RRSPORT.CO.UK | ||
|  | Home > Technical > Depressurizing the air spring |
| Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554    | There are a few posts on www.disco3.co.uk describing how to change the shocks. Might take time searching for them, but they're there somewhere. | ||
|  Mon May 03 2010 6:05pm |
| jetblasters Member Since: 09 Oct 2007 Location: Heathrow Posts: 31    | if you can borrow a Hawkeye or similar you can command the car to drop all the air out of the system completely.
|  Thu May 06 2010 6:23am |
| Micrometer Member Since: 26 Nov 2009 Location: Cambridge Posts: 39      | i would'nt change the dampers if you have ARC fitted as the roll rate will change and confuse the ecu however.. the easiest way to depressurise is to drop to access, disconnect the battery then jack the vehicle up high to drop the spring pressures then slowly and carefully unscrew the voss connectors in the valve blocks that feed the springs when they start hissing just leave them alone to deplete the air, dont rush this as the voss connectors are very easy to thread in the valve block (£££). i'd wear safety glasses etc when doing this incase the connector whips about. when its stopped hissing crack them off abit more and leave again etc.. Trust me, i'm an Engineer! | ||
|  Fri May 07 2010 10:14am |
| avartis Member Since: 10 Sep 2009 Location: UK Posts: 18    | I don't think I have ARC as my option doesn't include Dynamic Response. | ||
|  Mon May 10 2010 11:16am |
| Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554    | Don't worry - even if you do have arc/dr, it doesn't make a difference. The Bilsteins are good (but the B6 is not recommended for cars with dr) as are Koni and the Greek Spyros ones. It's a quick job once you find the instructions. | ||
|  Mon May 10 2010 1:33pm |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781      | Be careful, check with the manufacturers.
|  Mon May 10 2010 7:41pm |
| Micrometer Member Since: 26 Nov 2009 Location: Cambridge Posts: 39      | Leo,
|  Tue May 11 2010 7:14am |
| avartis Member Since: 10 Sep 2009 Location: UK Posts: 18    | Yes,
|  Tue May 11 2010 5:45pm |
| Posting Rules
