![]() | Home > Maintenance & Modifications > Misfire / judder on acceleration - any thoughts? |
| bevlawyer Member Since: 08 Jun 2009 Location: derby Posts: 22
Research this morning has thrown up:
| sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961
How did you come up with these mate? |
Just from googling around. Any ideas yourself? |
Well if just serviced by main dearler then all filters would of been changed so no water in fuel. With diesel then plugs should be ok. Split in turbo hose or ecu could be. Do you have any break down cover cause they could have a look free of charge. Turbo hoses can be done diy but ecu will be dearler. |
Thanks. Would the split turbo hoses be visible under bonnet ie for me to diagnose? |
Even a pro would find it hard to find a small split. Check all the hoses anyway you never know. Its a big engine so as long as your a bit confident you might be ok. Good luck. |
| 5c0tty Member Since: 14 Sep 2012 Location: London Posts: 33
Hi bevlawyer
