Home > Maintenance & Modifications > stubborn mark removal off alaska white??
kedz
United Kingdom 2009 Range Rover Sport TDV6 HSE Alaska White
has anyone got load's of tiny dot's of dirt on the lower half of there alaska white rrs that are near inpossibe to remove what would i use to get the sucker's off?? Confused 09 alaska white black 22 saker's black gril's an vent's all black lettering black lr badge's inside and out tint's side step's turbo chip power upgrade full kahn exhaust colour coded every thing 2010 rear led's lowed by 45 mm
Post #260715 Wed Mar 24 2010 2:17am
Bradders
Sounds like you've got tar spots on the paintwork. Easily removed by using a clay bar. Check out these links;
http://www.cleanyourcar.co.uk/detailing-clay/cat_9.html
http://www.polishedbliss.co.uk/acatalog/cl...cants.html
Some basic kits in Halfords too.
Let us know how you get on. Be warned - its addictive! Thumbs Up FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #260720 Wed Mar 24 2010 7:28am
I get the same problem on mine
I find they are little tar spots, even though it's through the winter and some contaminates
a good wash with pressure washer, autosmart tardis(a tar remover) and a megiuers clay
bar kit, a rewash, then I have to re wax the panels as this would strip anything off them
some if my spots are also orange rusty coloured fleck which I presume is some sort of iron filing
Post #260724 Wed Mar 24 2010 8:14am
JimWD
As above.. If you look CLOSE, you will notice a whole array of wierd and wonderful deposits on the vehicle's paintwork..
Ideally, you should clay & cleanse once every six months. Protection should be topped up every three.
This should see you on top of the contaminents before they get 'too' engrained.. AS Tardis is brilliant for melting tar deposits (also v.useful for shift grease/muck in engine bay, door shuts etc..) and then a clay-bar (I'm currently using Sonus Green..) will see the removal of other fallout that Tardis does not shift.
..next time you clay your car, give the rear window a good going over, too. Quite suprised how much it lifts off!
Post #260731 Wed Mar 24 2010 8:57am
This is my before Pictures
I'll post some after shots once i get round to sorting the spots out Embarassed
Post #260761 Wed Mar 24 2010 12:28pm
