![]() | Home > General > Easy way of getting to the back of Radio? |
| AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174
I know it looks daunting but the panels just pull off....
| musher Member Since: 07 Feb 2010 Location: portsmouth Posts: 44
Alex,
Hi there... I last did this when I installed my Bluetooth... |
Alex,
There are 5 electrical connectors that plug into the bottom of the gear selector section... You will see when you come to pull up on that bit of interior.... |
Let me get this right. Once I have removed the gear selector cover, I then pull up the center console both sides from the arm rest end and should then see the connectors before I actually remove the whole thing or should I see them before then????
O.K. Here goes....
Would you mind, that would be great if you could |
1. Remove the 2 covers ( pic 98 ) Note: I found that the connecting piece between them came away as well....
Alex,
Keep the faith.... It will sound like something is breaking but it didn't for me....
