Home > General > Lumpy Steering
robinc
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Nara Bronze
Lumpy Steering
I've got a 2006 model TDV6. Been pretty happy with it. Had the 60K service a month or so ago. At the same time I replaced all 4 tyres with 205/50 VR 19 Vredestein Wintrac's. Ever since then (maybe it was just co-incidence) the steering feels very lumpy, especially at low speeds and definitely worse when starting up from cold. When you turn the wheel it feels heavy then goes light then heavy again as you turn it. I've checked the power steering reservoir, it's as it should be and no sign of any leaks.
Before I take it back to my LR dealer, anyone got any theories as to what this might be?
Could the tyres cause that effect? Hard to see how...
Thanks,
Robin
Post #258775 Tue Mar 09 2010 7:02pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
if noticeably worse when cold, my guess is the new tread/rubber - its a common report on Boxsters
Post #258791 Tue Mar 09 2010 9:27pm
KiwiRRS
New Zealand
Ball Joints?
Check the ball joints. Earlier cars had "light" ball joints that may fail. These have since been redesigned and are much beefier.
Post #258792 Tue Mar 09 2010 9:31pm
Texstar
Are the tyre pressures correct? I think vredestein suggest running them at higher pressures than LR put on the door sticker. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #258804 Tue Mar 09 2010 11:58pm
robinc
Thanks for the various suggestions. Is checking the ball joints something I can easily do myself or do I need to go to a LR dealer for that?
Tyre pressures are running at the Vredestein recommended values (+6 psi wrt standard).
Post #258874 Wed Mar 10 2010 3:55pm
robinc
Lumpy Steering : the outcome
For anyone whose interested this turned out to be a half-seized universal joint at the base of the steering column. According to the LR dealer mechanic who fixed it (a nice, genuine guy who I've known for several years) it's the first time he's come across this on a RR Sport (that's only 3.5 years old) but apparently it's quite a common fault on older models of Discovery. Not expensive to fix and it's certainly nice to have my silky smooth steering back again Very Happy
Post #260937 Thu Mar 25 2010 6:44pm
MAW
Thanks for taking time to close the loop Thumbs Up
Post #260960 Thu Mar 25 2010 10:15pm
