Home > Technical > WON'T COME OUT OF PARK !!!
feg355
2007 Range Rover Sport TDV6 HSE Java Black
HI . ANYONE .MY 2.7 DOES'NT WANT TO COME OUT OF PARK. TRIED NUMEROUS TIMES. ANY IDEAS PLEASE.[/b]
Post #258807 Wed Mar 10 2010 12:10am
Texstar
You are pressing the brake pedal when you try this, aren't you?as it has an interlock. Or if you are on a slope, the park pin may be under some load. so will be stiff to move lever. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #258808 Wed Mar 10 2010 12:22am
feg355
yes footbrake is pressed but it is on a slight incline. Do you think if i get some able bodies to push fron front it might release!
Post #258809 Wed Mar 10 2010 12:30am
Texstar
Yep,it should do,but you'll obviously have to leave the foot off the brake, til your very burly helpers Laughing have pushed it uphill a little, and the load is taken off the pin.Thumbs Up RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #258810 Wed Mar 10 2010 12:33am
Bobby
Start your engine, place your hand on the gear selector lever and apply the foot brakes.
You will "feel" a slight "knocking" movement in the gear selector lever. This is the shift interlock solenoid being energised so that the selector lever may be moved from the 'P' position.
If you do not feel anything then it could mean there is a failure of the interlock solenoid and you cannot shift out of P. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #258817 Wed Mar 10 2010 3:00am
Misery
Once again THANK YOU BOBBY. Bow down Bow down
Post #258841 Wed Mar 10 2010 11:43am
