![]() | Home > General > Sorry, another question... |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 ![]() ![]() |
It should be a simple case of turning her down when she speaks and you retain that level until you turn it up again!
Arnold1968 Member Since: 07 Feb 2010 Location: Midlands Posts: 11 ![]() ![]() ![]() |
That's what I would expect to happen and what has happened on my previous Audi's and BMW's. On this one she definatly returns to the high volume the next time she gives an instruction. I will try again this afternoon, thanks. 2009 Stornaway Grey HSE |
I'll have a play with mine again later this afternoon to see if there is any other way in the settings mode.
gordon kerr Member Since: 14 Jan 2010 Location: Bedford Posts: 49 ![]() ![]() ![]() |
Can't give you exact instructions (manual is in the car and I'm in the office) but the Sat nav instruction volume is set in the Sat Nav menus somewhere and is set as an offset from the volume that is being used for the audio. So if like me you have to set the audio level high (so that I can hear the music from my MP3 player which for some reason is quite quiet) then you get loud plus more volume for the sat nav instructions!
Ah thanks, that's what I was hoping someone would say but I couldn't find where to set the master volume, either in my handbook or by playing around with the menus. Would be grateful if you know where to set it. Bit of a pain about the phone problem but sure i will learn to live with it. Thanks. 2009 Stornaway Grey HSE |
You can also alter the satnav volume if you are quick enough to increase/decrease the volume while she is talking. |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
if I remember correctly, you have to hold the stereo key that allows you to set the bass, treble, fad...down for a few second, it will bring another set of setting that the one above with the satnav off set volume setting.... Range Rover Vogue ‘17 TDV6
Great, thank you, will try tomorrow. 2009 Stornaway Grey HSE |
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 ![]() ![]() ![]() |
If your not quick enough to adjust the offset whilst she's talking push the replay icon and adjust while she talks again. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
NickM Member Since: 15 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
I always turn the voice off.... |
Bigby Member Since: 09 Feb 2010 Location: Marlborough, Wiltshire Posts: 83 ![]() ![]() ![]() |
I just wish i could turn some of it off
You might find this link of some help...............................
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
personally I just turn the voice off completely and keep an eye on the screen |
Thanks Tim, couldn't find anything for the 2010MY that was not in the printed manual. Am i being stupid, fussy etc? |
