Home > General > How best to use a TDV Engine for short trips?
Aff
United Kingdom 2008 Range Rover Sport TDV8 HSE Santorini Black
Ok, I've had a sleepless night working out how to enjoy my incoming RRS on a daily basis. I'm sure there are owners who have to constantly make short trips or live close to their work. At present my Audi A5 V6 3.0TDi is doing 1.5 mile trip to work every day, hardly heats up but hasn't had a problem at all.
With the due TDV8 I could be doing 1 mile trip (one way) which tbh I'll probably walk or bike mostly. However there will be many occasions I will have to drive to work as I will need the car for meetings during the day.
I totally understand the wear and tear on any engine, diesel or petrol for short trips and I will also run on average two trips (25 mile) a week and one long one.
My question though is, for the inevitable short trips, what is the best way to get from A-B? idle for a while, not at all, drive slowly, use different diesel, more regular maintenance, etc?
I'm no expert in diesel engines but have heard they can fare better than petrol for short trips. maybe this is a myth though.
Sorry for starting another thread but hoped it may attract drivers of older models as well as new to see if any are still going strong on short trips.
Thanks
Aff
Post #257350 Fri Feb 26 2010 11:47am
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Fuel consumption will be poor, but would think little effect in the long term.
Longer trips to business meetings etc would enable the engine to warm up and get rid of condensation and carbon build ups. No engine should be thrashed when cold and condensation can build up in engine so more regular oil changes would help.
Park the car at work and bike or walk in so then the car can be used for the longer trips if you are really worried Smile
In Guernsey with a top speed limit of 35mph and small trips has caused me no problems but this has been balanced by longer trips back to UK with mostly dual carriageway and motorway work.
Post #257355 Fri Feb 26 2010 12:23pm
Tim in Scotland
I don't know if the service indicator is triggered by use or if it is only elapsed time/miles but you may find you have it flag up that a service is due more often too with that sort of use. Best thing would be to avoid using the car on really cold days for such a short trip. Honestly you really should consider a used S/C as gasoline engines warm up much more quickly than diesels and, especially in cold weather, the TD will trigger the Fuel Burning Heater which the S/C doesn't need and which uses even more fuel.
The other thing you will totally knacker on such short trips is the catalytic converters, regardless of whether it is a diesel or a gas engine, and if you have one with a DPF you will get lots of problems with that 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #257356 Fri Feb 26 2010 12:29pm
Aff
Fuel consumption is not a major issue as I'm not expecting great things from a V8 and I will also be doing motorway miles at least once a week.
Leaving the car in the car park, uugh, all alone at night. Not round here Laughing
All I was looking for was some 'best practice' approach. Hopefully it'll all work out.
Post #257357 Fri Feb 26 2010 12:31pm
flydive
As Tim said, if you have DPF it might fill up quickly
But if you do a bit of motorway every week you should be ok. '08 RRS TDV8
Post #257358 Fri Feb 26 2010 12:35pm
Tim in Scotland
If your Audi handled the same treatment without any problems then your RRS will too! Fuel consumption on the TDv8 is quite reasonable, town drivers seem to get 20-24mpg on longer trips anything between 26 and 34mpg depending on how you drive and length of trip - I'm getting 26-28 mpg on fast A roads, with no commuting and 32-34 on long haul runs (200 miles + and using the cruise control) on my longest trips (Central Scotland to Southampton 2-3 times a year) I can get 33mpg easily when the car is on it's normal 20" summer tyres, currently I'm on 19" Snow and Ice tyres and it has increased slightly and the mpg is 25 at the moment (by the trip computer) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #257359 Fri Feb 26 2010 12:36pm
C10KO
Mate, there is nothing to worry about. My mum uses her FFRR TDV8 (previously TD6) to drive to office (about 2 miles). In the last 8 years she hadn't had any problems at all. Only advise would be to stay gentle with the throttle whilst the engine is cold. Though if I were you I would give the engine occasional blasts when warmed up Wink
Post #257360 Fri Feb 26 2010 12:48pm
Jonny Fresh
My daily commute is 2 miles each way and I am never gentle on the throttle or worry about the engine being cold.
No problems here.
Post #257366 Fri Feb 26 2010 1:22pm
Lawrence22
2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
I used to drive a Mazda RX8. When it was cold the engine was limited to 6000rpm, when it heated up you could take it further 9000+. I am surprised that land rover and other manufacturers haven't fitted similar systems to prevent damage to cold engines. Said RRS is now on order.
Post #257371 Fri Feb 26 2010 1:56pm
Aff
The car will be under warranty (will extend at 3 years) so is there anything in it about not making short trips?
Post #257394 Fri Feb 26 2010 5:41pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
the battery is the one weak spot I have on mine and if I done a lot of short trips like that in this cold weather the battery would be dead by the 5th run Sad Sons of dogs come hither and get flesh
Clan Cameron
Post #257404 Fri Feb 26 2010 6:50pm
Tim in Scotland
Have you thought of fitting a 2nd battery? Wink 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #257412 Fri Feb 26 2010 7:55pm
Alicatt
Rolling with laughter Rolling with laughter Rolling with laughter
No
And Victor hasn't mentioned it a 1000 times over the last week or so...
Big Cry Big Cry Big Cry
Mr. Green Sons of dogs come hither and get flesh
Clan Cameron
Post #257417 Fri Feb 26 2010 8:22pm
4wheeldriver
Scotland 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
Go Victor!! Go Victor!! Go Victor!! Rolling with laughter Rolling with laughter Rolling with laughter Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
535d m-sport Platinum grey and a few extras.... Gone
X5 3.0 sd in Space Grey, 20's, Dynamic Pack, Memory Pack, Media Pack, Tow Pack, Rear DVD, Panoramic Sunroof, Steps, 7 Seat Pack, Reversing Camera with moving lines, programmable park heat, etc etc etc - Gone
Range Rover Sport Santorini, privacy, dvd, towpack GONE!!!
Post #257430 Fri Feb 26 2010 10:45pm
MAW
Who would know you usage / driving style Thumbs Up
Post #257434 Fri Feb 26 2010 11:11pm
