![]() | Home > General > side step silver trim missing !!! |
| simonsti Member Since: 29 Apr 2006 Location: staffs Posts: 193
Both of mine have fallen off at different times, luckily they fell off close to home, unluckily i ran over one of them! They are now screwed on from the back. 2014 Nara Bronze SDV6
| steveb Member Since: 18 Feb 2010 Location: Grimsby Posts: 3
did you buy a replacement, if so where did you get this from please as I cannot locate any ! |
| Alive Tuning Member Since: 17 Mar 2009 Location: North East Lincolnshire Posts: 71
Hi Steve, Hope your car is running well, and staying shiny! |
Hi Gary
I managed to straighten mine out enough to screw it back on, only bent the ends. 2014 Nara Bronze SDV6
| j8keyboy Member Since: 09 Oct 2007 Location: Loughborough Posts: 37
Same has just happened to me and LR inform me that you can't buy the siler trim on its own! I still have the trim that has fallen off however the screws have snapped off inside the trim! FOR SALE
| accyis Member Since: 06 Feb 2010 Location: Lancashire Posts: 109
The same has happened to mine today whilst washing it. I noticed they were loose and when inspected they simple lifted away from the step plate. The original silver trim was rivoted on. These can be drilled out or chiselled off and then replaced with a self tapping roof sheet screw in the existing holes. Took about 30mins to do the pair and now as solid as ever.... hope this helps |
| gwdalba Member Since: 03 Sep 2010 Location: Nairn Posts: 46
Did you finally find a solution or resort to purchasing the new side steps. Just 'lost' my trim on my 4 year old RRS - can't believe it dropped off as the car has done only 9,800 miles! |
| johnsmall Member Since: 28 Dec 2010 Location: bristol Posts: 18
both of mine has gone to, bought the car (private) without them on, seller told me you can get them for about £30 on ebay. what a load of crap, been looking now for about three months aint seen none only full complete steps.
| chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950
Same happened to me, i contacted dealer who repaired F.O.C, i asked about replacing them both with new as the car was under warranty but they said no. It is a common fault according to them.
| mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705
One to watch,maybe |
| Storn Member Since: 27 Jan 2011 Location: IOW Posts: 22
After reading this I checked mine today and one is not attched and therefore loose at the front. Can these be fixed back on while the steps are in situ? Is it just simply a case of drilling out the old and using the same original hole and self tapping screw? Would you suggest drilling all of them out and fixing all of them more securely, or just wait until nature takes it corse and fix as and when? There's only one service centre here on the IOW and I'm not sure I can be bothered to take it to them if it such an easy fix. |
| Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657
Out of curiosity, how old do side steps tend to be when they begin to fall apart?
My car is 07 with 35k, but I don't think the milage will have much to do with it..I think it's just a bad design. I just fixed mine, stick your head under and take a look, it's pretty self explanartory. Drill out the old and pop a scew in. |
