![]() | Home > Technical > Cold morning starts? |
| panpicker Member Since: 27 Dec 2009 Location: buckingham Posts: 38
yes the other morning car started then cut out, did this 3 or 4 times. i had to flick the key keep my foot on the pedal for 30 sec then all was fine. but no problems this morning, Very strange |
| NickM Member Since: 15 Feb 2008 Location: London Posts: 2995
Diesel or Petrol? if Diesel you must wait for the glow lamp to go out - am sure loads of people don't...... |
Always wait for the glow lamp to go out. it was strange as it would not tick over. |
| alid32 Member Since: 30 Oct 2009 Location: Lancs Posts: 12
I had the same thing late last year...
| accyis Member Since: 06 Feb 2010 Location: Lancashire Posts: 109
Hi. It is diesel and I always wait for the glow lamp to fade out before turning the key. It's going in to landrover on Tuesday and was wondering if the fault maybe covered by the warranty? Also wondered what to expect in the way of cost. Little frustrated at the mo. Thanks for helping so far. All feedback welcome. |
The problem is getting worse, ie the time for the engine to run smooth is taking longer. Nearly caused an accident! Once the engine appeared to run smooth from start up i left my house. Tried to pull out of the junction at the end of the avenue and even with my foot to the floor there was nothing there at all. |
Not sure - both my EGR valves went last week and I was still on full power |
| zoo Member Since: 05 Sep 2009 Location: London Posts: 95
I've been trawling the forums looking for 'stumbling start' issues on my SC. This monday morning, it occurred and then drivers airbag warning light came on and stayed on. Car is still with dealer. I'm told that there is a TSB on this. Software update also. Should get it back tomorrow so will post the results for other Petrol owners. |
This is the same problem that i had, the dealer put it down to the EGR's...
Zoo has a 4.2 S/C - it's a different problem on the gasoline engined cars 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816
Mine is also doing this but only when the weather is cold and not too bad at the mo. Car is booked into the dealer to look at this and a couple of other issues in 2 weeks. |
| slcar Member Since: 24 Sep 2009 Location: Wigan Posts: 23
I had this on a TDV6 put new EGR valves and replaced two injectors that cured it but then it started again so changed the battery and it cured it so possible a voltage issue when it gets too cold!! |
Hi, just a quick update on the repair work. Car been at main dealers since Tuesday and the feedback I received is that they have found the problem with the EGR valves. They tell me that this has sorted the fault........ the car still has other issues being ironed out but I'll be a bit more specific when I get the vehicle back. |
still in the dealers since Monday - although I think it's because they are so busy that I doubt they have even looked at it. |
