![]() | Home > Technical > Vent grilles inside the wheel arches |
| NickM Member Since: 14 Feb 2008 Location: London Posts: 2995
How come you in tomorrow Tim? I am gong to into tomorrow AM for an EGR valve replacement.... |
Rattling DR/ worn bushes is getting another "fix" - this will be the 2nd time that it's been looked at. Also the upper section of the tailgate isn't opening so they are having a look at that too 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Maybe see you there during the course of the day.........EGV valve should get the amber engine management light off - finally!!!! |
You travelling up to Scotland then? Mine's going into Morrison's Land Rover Stirling not LPR 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275
"Due to package constraints an auxiliary radiator is required to maintain acceptable coolant temperatures under arduous driving conditions such as high-load and high ambient temperatures. This radiator is located in the in the RH wheel arch area, with cooling airflow supplied by a dedicated aperture in the front bumper. The auxiliary radiator is connected in parallel with the main radiator, with the coolant flow being controlled by the main engine thermostat." |
Never thought I'd see the day!!!! I am going to Newcastle on Thursday though, about as close as I'll get! |
| All times are GMT |
