![]() | Home > General > tailgate gas strut question |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
Yours is normal. The soft-close (powered latch for the last 1cm or so) was only introduced for 08my (from memory). All RRS before it need a good old slam!
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
This is a picture of the soft close mechanism fitted in the floor of my 07MY. It's a Ford part as you can see from the FoMoCo stamping. When the tailgate latch engages the U shaped anchor piece in the middle, it starts a motor which rotates the gearwheel on the right. This turns the crank connected to it which via more levers slides the U shaped anchor back along the mounting plate pulling the latch and tailgate down with it.
accyis
accyis Member Since: 06 Feb 2010 Location: Lancashire Posts: 109 ![]() ![]() ![]() |
Hiya, thanks for all your info. I thought as much due to it's year (05). With regards to the gas/oil struts being mentioned earlier i knew there had been some confusion so i'm glad it has been cleared up.
mrloudly Member Since: 30 Dec 2009 Location: Naseby Northants Posts: 48 ![]() |
Me being a muppet sorry... Increasing the strut oil will stop the tailgate from flying open and jarring the mountings upon reaching full strut extension. More a "soft opening" than "Soft close".
James, softclose came with 2007MY as I have it on my car. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539 ![]() ![]() ![]() |
Mine is a MY2007 and the tailgate is quite "heavy" in operation. Once it has got about halfway it does open fully but very slowly. On closing it is somewhat stiff and loses control about 8 inches (20cm?) from closure and close with a very loud crash onto the soft close which then takes over.
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
super gentle and quite sexy. Mine's a 57 plate. If still under warranty escalate to the Dealer Principal. Is it a Stratstones because they are a pain. |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
I'm sure I've read on another post that someone else had found corrosion and had the struts changed out under warranty. Mine are looking pretty ropey and so expecting a bit of a challenge to get them swapped out on next service visit. |
