Home > Technical > Suspension fault
max55uk
Suspension fault
Hi guys,
It's been about a week my RRS brings up the suspension fault message with orange light, if I lock and unlock from the remote it goes away however comes back on again after driving a few hundred yards.
Any suggestions ? Oh it's a 2005 out of warranty Sad . Hope it's not too costly already installed a new turbo!!
Post #253581 Thu Feb 04 2010 12:26am
PJPR01
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
99% likely that you need a new battery...that tends to throw these types of faults. PJPR
Cairns Blue HSE
180k Miles of Adventure
Post #253594 Thu Feb 04 2010 6:33am
MAW
If not that it could be a bad sensor - they are currently on recall and if you search on here and D3 you'll find posts on it - I had it around 3 weeks ago. LRA fitted a new sensor.
Post #253601 Thu Feb 04 2010 9:03am
C10KO
It can also be a water leak that has damaged your ECU - I have had a similar problem on a 2005 TDV6 Whistle
Post #253621 Thu Feb 04 2010 10:34am
Landlord
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Had the same thing 3 times over 3 years on my last Sport. Either cleared itself over night or dealer reset fault code. Hopefully its nothing much to worry about Thumbs Up MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
MY07 TDV6 HSE, Zermatt Silver, Gone
1964 Austin Healey 3000
2007 LR Defender
2011 VW Tiguan R Line
Post #253644 Thu Feb 04 2010 12:40pm
