![]() | Home > Technical > Brake disc - thickness when new? |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104
Unless your discs have been skimmed / dressed the level of 'step' should give you an idea of wear from new to current. You'll have a lip around the outer / inner edge where the pad has worn the face down - the outer edge sometimes corrodes away but the inner edge is more resilient. This tell tale sign should help a little ....
... and although also down to driving style the mileage can suggest when the discs ought to be done.... |
| Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275
Front
IIRC there is a detailed description for changing them somewhere on DISCO3.CO.UK. There is also a photo article on how to change the rears (on a Disco which is the same) in Feb 2010 Land Rover Enthusiast magazine P122. |
| tornado34 Member Since: 06 Dec 2009 Location: London Posts: 242
Aha, so when new there is absolutely no step or 'rim' edge? This is purey created by the wear?
Bob do you have (or could you) scan that article? It would be really useful, considering the risks with the EPB. I have read quite a bit about placing the EPB in 'service' mode and removing the fuse, but all reading is good, especially with such a sensitive thing and potencial high repair cost. |
I'm sure somebody posted on here how to do them last year................... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Have found enough info to sort front end, but the EPB concerns me. I'm happy with locking in into service mode and removing power etc. My big concern is this EXACT 8 clicks on the adjuster to release the shoes in order to get the disc / drum off and then making sure you crank the EXACT 8 clicks back. This sounds critical and difficult to do through the tiny adjustment hole. Will the disc / drum not come off without releasing the shoes? If the EPB is in service mode, surely the shoes are away from the drum? Have I misunderstood? MAW maybe? or Tim! |
| purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990
You need to have a Chat with MAW or Tim purple people eater
I am trying to picture it when i did mine but what are you doing with the EPB? |
From what I understand, if you want to change the rear discs you need to 'lock off' the EPB to stop it engaging. The EPB uses the 'drum' on the backside of the disc to push brake shoes against. (Correct me if I have got this all wrong!).
Ah - OK. I wondered why you were getting involved with the EPB when changing brakes - you are changing discs are you. you definately need to? |
Maybe I can go one more set of pads, but I need to go and check the rim step as you suggested.
A mm sounds low |
| All times are GMT |
