![]() | Home > Maintenance & Modifications > Do it yourself service? |
Personally, I wouldn't even attempt it, but then I am a bit of a mechanical luddite. While the stock service items like changing filters etc might be reasonably straightforward for someone who has the skills, it's the overall review of the state of the car that you'd be missing out on and the discovery of other less obvious issues that might normally be pointed out when a dealer tech goes over the car.
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104
| tornado34 Member Since: 06 Dec 2009 Location: London Posts: 242
That's the problem, I cannot find anyone in Stockholm who is more competent than me on LR (and that's pretty limited!).
suggestion Tornado - come over to the UK for you summer hols and book the car into LPR or one of the other forum sponsors for a service while you are here or even book it into a non-franchise LR specialist. There are enough ads for them in the Land Rover magazines. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
It's becoming more of a real option. 1500 miles each way though with a new born and 18 months old, maybe it's worth blowing £600 just for the peace and quiet of flying!! (2hrs)
| lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052
A lot of info over on D3 re servicing etc. do some searches and check stickies.
| rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551
It is an easy job to drop the sump guard to drain the engine oil and even easier to pull the plastic engine cover off to access the screw on oil filter canister. Cost 9 litres of 5W -30 oil and £8 for a filter cartridge. The car can be raised to off road height and axle stands placed under the chassis - just in case it decides to drop! Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
Thanks rrsjo & lespes.
| Bob Member Since: 19 Aug 2006 Location: Pump No. 3 Usually! Posts: 49
Anyone got any pointers on changing the oil and filter on a 4.2 s/c?
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
You have to remove the radiator access panel to see the oil filter, looking from below. |
Ah, thanks for that. I'll have a look as soon as the outside temperature gets above freezing. Bob. |
| acowx Member Since: 21 Jun 2009 Location: New Freedom Posts: 61
I can confirm that oil changes are a breeze, you do need to remove those two panels though. The big sump cover plate is a buggar if it lands on you ! Thing must weigh 30lbs ! I do mine every 3333 with full-synthetic, just for kicks really.... |
Agree the plate is heavy, I use a small trolley jack to hold it in place on the way off and way back on again - much easier than struggling upside down with your face so close! |
