![]() | Home > Maintenance & Modifications > Faults appearing already!!! |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
My advice on the handbrake (EPB) is Don't bother using it! They are prone to seizing and at the end of the day you really don't need it under normal day to day use. When the car is in "Park" on the gear lever there is a bloody great bolt that locates through the flywheel and therefore the car is going nowhere anyway! (well according to the LR Assist techie that came out to my 2007 HSE when it's EPB seized on anyway) I've never engaged the EPB since and have had no problems, even though my driveway is on a slope! |
Points 2 & 3 could be related to point 4. You might have some grit or a small stone lodged in between break pads 2005 Zambezi TDV6 - Gone but not forgotten
EPB had a redesign for 2007MY cars, same as D3 - I have not had one time when it seized on with the TDv8 whereas it happened a lot with my 2005 TDv6. I use it whenever I stop at traffic lights for any length of time and whenever I park. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tim, the one I had all the trouble with was an MY07 |
Maybe it was 2007.5MY then Endjin, my car is a 2007MY and has the new design 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Thanks for the reply VA but was happening before this! |
When you guys say seizing on, was it completly where as you couldnt go anywhere and wouldnt release at all resulting in calling out LRA? |
Yes, mine was a complete seizure and it actually resulted in the pads disintegrating! ![]() ![]() 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
Jimmy Salsa Member Since: 03 Mar 2009 Location: Hunter Valley Posts: 257 ![]() ![]() |
Was offroading a couple of weeks ago and stopped on a steep-ish incline so I could get out and guide the car following through a tricky rock crawl. As soon as I engaged the EPB there was a horrid squealing sound from the front left and then warning lights lit up the dash with a park brake failure warning.
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
Jimmy - I had the same last Mar whilst offroading around Dargo. Convoy had kicked up a lot of dust over a prolonged period, so I assumed this was the cause. As you did I turned off and on and all was well and not a problem since!
purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990 ![]() ![]() |
tuned it off and on again to get it going! |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
welcome to the world of Range Rover ownership mate |
rabbutler Member Since: 11 Dec 2009 Location: Aberdeen Posts: 187 ![]() ![]() ![]() |
X5PAE, you took the words right out of my mouth.
It's all about getting to know your LR service department. I think I'll make Will at Guava godfather to my next born! 2005 Zambezi TDV6 - Gone but not forgotten
