Home > General > Parking Sensor Help
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Parking Sensor Help
Last few days ive been getting a message syaing the front parking sensors are incative.
Common Fault?
Do they all stop working if one sensor goes faulty?
thank you in advance
Post #250314 Mon Jan 18 2010 8:51am
samd
Same here but back to normal yesterday - must be the weather!
Post #250318 Mon Jan 18 2010 9:24am
If one of the connectors is loose you will get that message. There are probably other reasons too. 2005 Zambezi TDV6 - Gone but not forgotten
Post #250319 Mon Jan 18 2010 9:28am
merwiz
I get that after i have washed the car, maybe some water gets in the sensor?? I keep telling myself 'It's a toy'
But I've broken quite a lot of toys in my time.....
Post #250320 Mon Jan 18 2010 9:33am
x5pea
merwiz wrote:
I get that after
Laughing Range Rovers are great arent they
Post #250326 Mon Jan 18 2010 10:02am
Tim in Scotland
Try also scaring the neighbours into thinking you have totally lost your marbles (they had suspicions when you appeared with an RRS anyway!) and get out that vital piece of the RRS toolkit, the hairdryer, and try drying them out after a wash - BTW never ever aim a pressure washer nozzle directly at them - a soaking in a river or deep puddle is different to having 10bar of pressure washer jet aimed at them! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #250331 Mon Jan 18 2010 10:24am
joka748
United Kingdom 2012 Range Rover Sport SDV6 HSE Alaska White
Me too. I thought it was ice / debris in a sensor but still inactive after warmer weather and a good clean.
Car is booked in for Thursday so we'll see.
Post #250477 Mon Jan 18 2010 11:12pm
P44RY C
Let me know how you get on Joka as I have the same problem.
Post #250655 Tue Jan 19 2010 5:22pm
joka748
Will do.
This is the first test for the LR Extended Warranty too.
Post #250703 Tue Jan 19 2010 11:22pm
joka748
Problem fixed by replacing one front sensor. Bumper removal was required but my warranty covered the £200+ bill. Result.
A word about the Dealer, Harwoods in Basingstoke. They are always able to book my car in within several days of ringing, keep me informed of how the work is progressing and fix the problems without creating new ones. I can recommend their services.
Post #251047 Thu Jan 21 2010 6:40pm
shuzzy
Seems to be a bit of a common theme here mine too! Had a rear sensor replaced not long ago and noe they have all started playing up. I get the message saying front parking sensors inactive (intermittently) and the rears stop working too. ARGH, anyways dealer said most likely a wire shorting behind front bumper and it would need to be removed to check. Quoted me £85 for bumper removal and check.
Post #252288 Thu Jan 28 2010 2:33am
