![]() | Home > Technical > MY10 Fuel Burning Heater (FBH) |
| Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087
I assume that the MY10 model still has an FBH fitted as standard and that it is only the
| ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750
It has indeed |
| rrsowner Member Since: 23 Dec 2009 Location: Out In The Cold Posts: 34
Must be a FBH on MY2010 otherwise I have a bloody big problem with the amount of diesel fumes and smoke coming out of the right hand side of the front of my RRS |
OK that solves that mystery - thanks guys. It's just that the 2010 pricelist makes it appear that there is no FBH on 2010 cars if you are speccing the Park Heat option. Does anybody who has Park Heat care to take a look and see if their car has 2 FBH's, one for emissions reduction in cold weather and one for the Park Heat system? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607
Tim
cheers for the Info chaps |
Well Endjin, jat least we know there is at least one FBH under the bonnet............. I wemt down this route with my first RRS, there wasn't even ONE FBH there when there should have been! It became a retro fit, but only if you knew about it and complained to the dealer about how cold the car became in winter. There must still be a few 2005 cars out there without them because the owners were not aware that there should have been one from day one! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| rajhirani Member Since: 05 Mar 2009 Location: london Posts: 53
Yes for all UK spec cars as it forms part of the cold weather emissions reduction kit. Both TDv6 and TDv8 have it, Supercharged do not 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| DHA Member Since: 09 Jan 2010 Location: Guildford Posts: 12
Is there an upgrade to the FBH available or is it standard with the remote function? The mrs was very keen on this as an option. |
| avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106 |
At least for my 07 there wasn't an option from LR available, it would only function to hear the coolant. There are possibilities to add a remote, as that will at least give you the ability to heat the car before you use it. It also seems that Webasto (the maker of the fbh), has a module where it can also control your blowers in the car, and making it thus a normal Park heater (only for pre my10 so far). Will get this one in a week or 2, when it will be warm again |
Looks like the Park Heat may have a technical problem.
| All times are GMT |
