| RRSPORT.CO.UK | ||
|  | Home > Technical > Stubborn locking wheel nut ***update with pic's*** |
| k11ngc Member Since: 25 Nov 2009 Location: colchester Posts: 51      |
 Can't get my front locking wheel nut off, the silver part of the locking wheel nut just goes round and round. Any advise how to remove,???? had a road side repair guy have a go and he said it was to big for the reverse thread wheel nut remover he had, So is there a tool I can buy to get it off or is there some other way????? Or will I have to take it to the  L R dealers
|  Mon Jan 04 2010 12:08am |
| ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704      | Usual options in this situation are:
|  Mon Jan 04 2010 12:05pm |
| Very Annoyed Site Moderator Member Since: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 19459    | Might be stating the obvious but do you have the correct locking nut? 2005 Zambezi TDV6 - Gone but not forgotten
|  Mon Jan 04 2010 12:08pm |
 You never Know !! but a bit too long in the tooth to have not checked all the other wheel nuts first .... but thanks anyway "Very Annoyed" Stephen Hughes Last edited by k11ngc on Mon Jan 04 2010 8:45pm. Edited 1 time in total | ||
|  Mon Jan 04 2010 6:44pm |
| Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555    | Happened to me. The nut had split from it's shaft dealer had to drill it out.   | ||
|  Mon Jan 04 2010 7:22pm |
| Ambrez Member Since: 13 May 2009 Location: Stourbridge, West Mids Posts: 36  |
 at what sort of cost??? this has happened to me also today..... | ||
|  Wed Jan 06 2010 3:09pm |
 How much am I expected to pay the dealer for he's time. Stephen Hughes | ||
|  Fri Jan 08 2010 8:57pm |
 Yes how much will they be asking for there time??? Stephen Hughes | ||
|  Fri Jan 08 2010 8:58pm |
| dasherdablo1 Member Since: 10 Jan 2010 Location: Hertfordshire Posts: 1  | Have you tried using an impact driver? Definitely worth a go as I have had similar issues in the past and it the only thing that will work! Just ensure the alloy key is in the right place before you strick the driver!
|  Sun Jan 10 2010 2:13pm |
 Sounds like a good simple Idea that may even work!! I need to push as well as turn the wheel nut, an Impact driver may just work coz I would be able to do this and the vibration may well undo it. Thanks for the advice DASHAERDABLO1 Will try before I take to L.R.......K11ngc Stephen Hughes | ||
|  Sun Jan 10 2010 6:45pm |
| Mail Order Ride Member Since: 28 Feb 2009 Location: UK Posts: 131  | You need a BFO version of this:
|  Sun Jan 10 2010 7:02pm |
 THIS TYPE OF TOOL WOULDN'T FIT OVER THE LOCKING WHEEL NUT TOP PART ( SEE PIC) COZ OF IT TURNING ROUND AN ROUND,AND IT ALSO HAS A FLANGE AROUND IT LEAVING LIMITED ACCESS. HENCE NOT EVEN A SLIGHTLY SMALLER SOCKET TOOL WOULDN'T FIT IN THE HOLE. But thanks anyway....Mail order ride Stephen Hughes | ||
|  Sun Jan 10 2010 8:12pm |
 Well went to a local garage and used their impact driver, and ....... it didnt work unfortunatly. just spun round! So it's booked in at local Garage, they are going to drill the cap off and then weld a nut to it through a tube or something? Will keep you all informed of progress and cost. K11ngc...(goes in tonight) Stephen Hughes | ||
|  Thu Jan 14 2010 10:29am |
| XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894    |
|  Thu Jan 14 2010 10:37am |
| Posting Rules
