![]() | Home > General > It was all going so well and then............... |
| purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990
i must be the lucky one reading all the posts, my sadly missed MY06, practicaly faultless, touch wood MY10 still running purple people eater
| RichardM Member Since: 25 Sep 2009 Location: Herts Posts: 745
Is it the full tailgate the has the problem or just the top part when you open that? I've noticed with mine the top part rarely seems to shut properly first time. I've given up using it as the main tail gate is always fine. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
| Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146
I had this issue but found out it was due to the car door handle be either dirty and/or cover with snow...seems to trigger the same reaction as when you touch them and the car unlock itself. Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
| Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285
Yes, I have the same problem with the top part, hasn't closed properly from day 1, so have avoided using it, think I need to add it to my list for the dealer. https://www.plus.net/refer.php?strReferral...d093cba6a7 Gone - RRSPORT TDV6 HSE Buckingham Blue/Ivory, Privacy Glass, Tasmods Sills, Supercharged Black Badges all round, Grille & Vents, plus RRSport Sticker & Brolly of course. |
| delboy633 Member Since: 28 Dec 2009 Location: stourbridge Posts: 4
Hi Red
| JonnyDangerous Member Since: 09 Nov 2009 Location: Reading Posts: 57
I have the same problem. I have to give it a good slam to close properly. |
Ahhhhh JD that will be the 2010MY special Hard Close tailgate mechanism.................................. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| Aitchy Member Since: 19 Nov 2009 Location: Peterborough Posts: 45
My 2010MY 3.0 SE, delivered 18th December, 1,200 miles ago,is lined up for its 3rd visit to the dealer on Friday This follows 2 home recoveries, firstly for the reduced power which was diagnosed as the valve on the turbo (?) and then a repeat for a gearbox fault resolved as the selector switch. Despite being "fixed" i now have the red triangle and reduced power message coming on intermitentley but switch off/on clears it. |
| Red1903 Member Since: 25 Jan 2009 Location: North East Scotland Posts: 156
Still not got the car back from dropping it off at the garage on Tuesday afternoon.
| mrloudly Member Since: 30 Dec 2009 Location: Naseby Northants Posts: 48 |
"the reduced power which was diagnosed as the valve on the turbo"
thanks. Despite the glitches its been running fault free now. As i wont need it for the next 2 weeks (operation on my throttle foot) i trust all will be well when i return to it in early Feb |
Time for an update.
Quick update.
The knocking noise is pretty bad on mine too, especially over bumpy roads. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
