![]() | Home > Technical > behind the front brake calipers two steel cubes... |
| Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087
| Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275
The two weights are there to stop brake resonance on the Brembos. They fit inside a standard LR 19" wheel as long at the balance weights are the stick on type.
| Norberto Member Since: 05 Dec 2009 Location: Milan Posts: 14
Hi Bob,
| lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052
Are you fitting GENUINE landrover wheels or another make |
| Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554
No, problem. You might get some brake noise though. There are many 19" rims which fit without any modification - including all the LR ones. |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Yes, I have mounted four "Radius" different rims. (an italian brend).
Don't understand this but I hope you're not using the HDC button to slow down!!! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944
Ciao Norberto, il rumore "metallico" del sistema Hill Descent Control / HDC (innescato con il bottone giallo) e' sicuramente non piacevole ma perfettamente normale, generato dall'uso molto aggressivo dell'antilock e marce basse per mantenere il controllo del veicolo e una velocita' bassissima durante discese molto scoscese. Il rumore lo fanno sia i freni normali che i Brembo, i blocchi di metallo anti-risonanza montati dietro alle pinze non fanno alcuna differenza. Per evitare di danneggiare freni e trasmissione, non usare mai il sistema HDC, eccetto in caso di discese ripide e sducciolose dove rischieresti di perdere aderenza usando solo marce basse e freni in modo normale - HDC e' utile soprattutto fuoristrada, cosi ti concentri solo sulla guida e lasci che la macchina freni per te... Non toccare l'accelleratore durante l'uso dell' HDC, altrimenti il sistema si disinnesca automaticamente e quando molli l'accelleratore e l'HDC si innesca di nuovo rischi di picchiare il naso contro il volante! |
Tkanks, Umberto!
Umbertob to the rescue...................................... sounds like Norberto activated the HDC at speed |
Sorry Tim, I don't understand your msg. |
| ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704
Yes this is perfectly normal. HDC makes this noise always! WINNER - 2008 Best All New Photograph WINNER - 2009 Best All New Photograph |
| All times are GMT |
