![]() | Home > Technical > TPS Tyre Pressure System |
bananenschale Member Since: 03 Jan 2009 Location: Moenchengladbach Posts: 178 ![]() ![]() ![]() |
Hey,
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
The LR system is not so clever, it just warns you that a tyre has a low pressure and to check all tyres. I had a much better system on my Renault Laguna it showed each individual wheel pressure. You had to refit the valves to the correct wheel when changing the tyres so you couldn't swap the wheels around. Sons of dogs come hither and get flesh
ahh, ok. and whats that for a system which you have? RRS TDV8 Modelyear 2009 with some modifications. |
I have the Landrover TPMS on my RRS it was fitted as a factory option.
Bobby that last line is incorrect, it does not show an individual tyre, you only get a message to tell you to check all tyres. Sons of dogs come hither and get flesh
Maybe region-dependent, seeing as that text was clearly written by one of our American friends? |
My vehicle is not equipped with TPMS, hence I am not sure how this works. The quote above is from some LR literature in my possession. Anyway, I have checked further and came across this description on the TPMS Module...
If the above is wrong, please do not shoot the messanger! ![]() Just trying to contribute! ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Thanks for the info, Bobby |
Yes Bobby I'm not shooting the messenger, I had read that too before specing it for my car, just the operation in "real life" differs from what was in the brochures.
twozzie Member Since: 15 Dec 2008 Location: California Posts: 21 ![]() ![]() ![]() |
I thought I'd hijack this thread so I didn't have to start another on the same TPMS subject
Any idea how the system knows what pressure to monitor? Is it based on the std tire size for the car and if so what are the tolerances? On the wifes Merc, you set the tires to the correct pressure, then tell the system it's all set to go at these pressures - simple. |
