![]() | Home > Technical > ARM (anti roll mitigation) QUESTION |
| Micrometer Member Since: 26 Nov 2009 Location: Cambridge Posts: 39
ARC or Dynamic response was fitted from Job1 RRS on V8SC and optional fit on V6D if the sport pack was fitted. It was also fitted standard on V8D when that came in more recently.
| BIG BAD RANGE Member Since: 24 Nov 2005 Location: KENT Posts: 64
Many thanks for the detailed reply , my other RR Sports the knock was to be fair between 5 - 30 mph and going over uneven road surfaces. |
Just purchased a 08 TDV6 S , and not sure if it has ARC or Dynamic response , being an S model may be it does not have these extra bits as standard ?
If it has 20" wheels then check and see if it has the extra hydraulic oil tank under the bonnet that the ARM needs, if it has that then somebody paid for the Sport pack (I could think of better extras to put on an S!). According to my 2006MY brochure it should also have Brembo front brake calipers and Bixenons if it has the DP or Sport pack. As you say you don't have the Bi-Xenons then it is highly unlikely you have the fancy systems! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Car came with the standard 18inch alloys , and has no xenons , so i guess no sport pack and no ARM system so may be no knocking from the suspension ? |
