![]() | Home > General > adaptive headlights - beam too low |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Zoo - the bi xenons on my TDV8 definitely go through some sort of noticeable self levelling check when turned on. They then settle down very quickly. Hope you get sorted. |
purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990 ![]() ![]() |
same theme, but different angle so to speak, i tend to get flashed a lot when driving on dipped beam as if oncoming vehicles think I am on full beam, still only 2 months old, do they need aligning or anything purple people eater
Mr Tim Member Since: 22 Aug 2008 Location: Essex Posts: 1 ![]() ![]() ![]() |
All,
I had a problem with my lights when new. Do the lights seem fine when first switched on and then very bright once you have used the full beam? If so your problem might be in the headlight unit. There is a little flap inside the light that goes up when on full beam, this flap can stick in the up position. You can bodge the job to fix it but best get the repair done on warranty - new light needed. 2005 Zambezi TDV6 - Gone but not forgotten
Robin Member Since: 28 Oct 2009 Location: Cumbria Posts: 16 ![]() ![]() ![]() |
Zoo, adaptive headlights were standard on S/C from day one - I would suggest that the previous owner had changed the unit to similar ones to the Hawks that I had on my car and used the standard non-adaptive lamps to save money at part exchange time. At £544+Vat each, headlight units are not cheap items to replace so they will not be keen to swop them without a fight, even though the car is supposed to have adaptives 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sorry misread this post - as Tim said the SC came with adaptive xenons as standard, I would push the dealer on this - it is what you paid for and you might have a problem when you come to sell. 2005 Zambezi TDV6 - Gone but not forgotten
