Home > Technical > Drivers Door Locking Problem.
Aidan
Ireland 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Hey there people, been a long time reader never had to actually join up and post until now. Drivers door wont lock anymore by the key fob. All other doors lock but not drivers, the snib on the inside feels a little rough to close, it works from the central locking button on the dash. fella said it might be a worn solanoid. Any help is appreciated.
(Had it with my mechanic and he took off door fascia but not specialising in Land Rover decided to go no further because of access difficultuies to locking mechanism) It can't be that hard on diesel???
'06 TDV6 Buck Blue. 22s.
Post #236308 Fri Sep 11 2009 10:16am
V8 andy
England 2009 Range Rover Sport TDV8 HSE Arctic Frost
what years yours aiden..? i had same problem with mine & was fixed under warranty & if i remember it was solenoid that had gone.
andy.
Post #236310 Fri Sep 11 2009 10:22am
Yep, this is quite a common issue... if under warranty, simple to get fixed Thumbs Up
Post #236313 Fri Sep 11 2009 10:26am
Aidan
Feb 06 Sad It can't be that hard on diesel???
Post #236315 Fri Sep 11 2009 10:31am
OK, cheaper to find an LR indy then... he'll know what he's doing with the product (hopefully) but won't cost you £120/hr in labour Very Happy
Post #236317 Fri Sep 11 2009 10:38am
Aidan
I can probably get a damaged door from breakers real cheap, use the good parts from the inside. Whats an "indy" though? It can't be that hard on diesel???
Post #236318 Fri Sep 11 2009 10:40am
An independent LR specialist - worth using them after warranty has expired, as they are much cheaper especially when larger pieces of work are required where main dealer rates would make things very expensive.
Post #236319 Fri Sep 11 2009 10:44am
V8 andy
just been oh this site & found this it might be usefull.
http://www.landyzone.co.uk/lz/f8/disco-1-d...83901.html
Post #236321 Fri Sep 11 2009 10:46am
Aidan
No chance it could be DIY? Or call in a favour from just a friendly grease monkey? It can't be that hard on diesel???
Post #236322 Fri Sep 11 2009 10:49am
V8 andy
ive just googled (rangerover spares) & theirs a few breakers breaking rrs.i would'nt think it was a hard diy job.
Post #236324 Fri Sep 11 2009 10:53am
I'm the least mechanically minded person here, so it could be easy enough for someone who knows what their doing I suppose - not sure Whistle
Post #236325 Fri Sep 11 2009 10:53am
Aidan
I used to be pretty good at Lego Smile
V8 Andy, just read the page you posted, holy fook there's alot of locking and unlocking going on there, felt like I wanted to boil my head. My mechanic said that when he had the door fascia off he couldnt actually get working at the locking mechanism because of a sheet of metal or something. I called him a lightweight Confused It can't be that hard on diesel???
Post #236329 Fri Sep 11 2009 10:57am
redrangey
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
had the same problem on drivers door and yes when you tke the door card off you cant get to the mechanism
but the cable that connects the door lock and mechanism i think is the culprit so i held it up and drowned it in wd40
problem solved ,
Post #243912 Sat Nov 28 2009 12:27pm
