| RRSPORT.CO.UK | ||
|  | Home > Technical > Locked in low range |
| 640Newton Member Since: 01 Sep 2008 Location: Sydney via Wolverhampton Posts: 231      |
 Nearly two weeks ago my RRS decided to lock itself in low-range.  It has been with LR since then and I have now lost any faith in their ability to fix it, so I've come to the experts to see if you can suggest any solutions that I can give to LR.  So far LR have:
|  Mon Nov 23 2009 9:38am |
| Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554    |
|  Mon Nov 23 2009 10:10am |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781      | 3. the transfer case control module can sometimes shut down due to thermal overload
|  Mon Nov 23 2009 10:47am |
 I didn't ask them about the fault numbers but I will certainly ask them tomorrow as well as give them the possible causes you and Leo have listed here. Thanks Bobby & Leo for the suggestions. 2008 TDV8, Stornoway Grey with Alpaca premium leather, Adaptive cruise, Adaptive Bi-xenons, sunroof, Premium Nav, Premium ICE Logic 7, telephone, active locking rear diff, console coolbox, seat memory, powerfold mirrors, tow pack, window tint, dual battery, engel fridge, Goodyear Mud-Terrain tyres. | ||
|  Mon Nov 23 2009 10:53am |
| 2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382      | 640, If Bobby's wisdom fails to point your dealer in the correct direction, then I would suggest you promptly move to reject the car, and if necessary use the NSW equivelant to Consumer Affairs Vic and VCAT..
|  Mon Nov 23 2009 10:57am |
| PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355      |
 I once had the opposite - I couldn't get it to go from high range to low range after a particularly vigorous offroad adventure. After trying the switch a few times, I decided to check the manual and see if there's a fuse which controls this. Lo and behold...that did the trick...just replaced the fuse and it worked again. Maybe worthwhile checking yours as well...as it may be just the opposite scenario. PJPR 2017 FFRR TD6 Former LR: 2013 RRS, 2006 RRS Last edited by PJPR01 on Tue Nov 24 2009 1:45am. Edited 1 time in total | ||
|  Tue Nov 24 2009 1:43am |
| 640Newton Member Since: 01 Sep 2008 Location: Sydney via Wolverhampton Posts: 231      | Just had a call from LR and they have decided to replace the entire transfer case as they believe it to be an internal failure.  It will take about a week or so to receive the parts from the UK so hopefully that will solve the problem.  Can anyone confirm whether replacing the transfer case also involves changing the control module?
|  Tue Nov 24 2009 1:44am |
| 640Newton Member Since: 01 Sep 2008 Location: Sydney via Wolverhampton Posts: 231      | UPDATE
|  Fri Dec 11 2009 1:51am |
| PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355      | Not to beat a dead horse...but did you get them to check the fuse, as per my post 2 posts above? PJPR
|  Fri Dec 11 2009 2:03am |
 I also do not want to beat a dead horse, but refer to my post above   But this type of poor service where the official dealer is effectively guessing what is wrong is more common than you would think, and i would suggest you reject the car as "not of merchantable quality" soonest!   | ||
|  Fri Dec 11 2009 5:38am |
| BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942      | Get them to call Lance Dixon in Melbourne. They seem to know the cars inside out!
|  Fri Dec 11 2009 9:58am |
 Hi PJPR01, yes they have checked all of the fuses and no joy there either. 2008 TDV8, Stornoway Grey with Alpaca premium leather, Adaptive cruise, Adaptive Bi-xenons, sunroof, Premium Nav, Premium ICE Logic 7, telephone, active locking rear diff, console coolbox, seat memory, powerfold mirrors, tow pack, window tint, dual battery, engel fridge, Goodyear Mud-Terrain tyres. | ||
|  Fri Dec 11 2009 12:45pm |
| Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554    | Get them to change the transfer case control module (ecu).
|  Fri Dec 11 2009 12:58pm |
| islider Member Since: 19 Jun 2009 Location: Deepest Darkest Hedgeland Posts: 457      |
 Read fault codes? More like clear them - wash car, give to Customer. LR Customer Service at it's best.   | ||
|  Fri Dec 11 2009 1:13pm |
| Posting Rules
 that's a new one....
 christmas... not!
  christmas... not!
