![]() | Home > Technical > Error messages - Please help ! |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
Mate, the message can have dozens of causes and so best is to get the error message reading. If it happens again my advice would be to ring the LR hotline to send someone to have a look. This way you at least report the problem to the customer service centre as the dealer does not necessarily have to do it, especially if it was caused by him in any way. |
Kilovolt Member Since: 26 May 2009 Location: South Derbyshire Posts: 50 ![]() ![]() ![]() |
I have a feeling the techy whizz boys are quiet this afternoon but this has been reported before I'm sure as a direct result of low battery voltage (the whole thing goes bezerk on low volts). The old R2D2 computer does not like low battery volts.
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
Right on target here...all signs of a low battery. PJPR 2017 FFRR TD6 Former LR: 2013 RRS, 2006 RRS |
It is not necessarily a low battery.
marcusjames Member Since: 15 Nov 2009 Location: Zug Posts: 6 ![]() ![]() |
Thanks guys. I'll try that avenue.
How old is your car? Are you the first owner? Where have you bought the car? If I were you I would open an official dispute in the country where the car is registered with Land Rover. Just ring the LR customer care centre in CH, they will be able to help you out... |
islider Member Since: 19 Jun 2009 Location: Deepest Darkest Hedgeland Posts: 457 ![]() ![]() ![]() |
Coko,
