Home > Technical > Are your Front Fog Lights working + Access to Interior Fuses
Bob.
I found that my front fog lights weren't working, the 15amp fuse had blown.
The dealer tells me that it is quite common due to wiring insulation chaffing through behind the bumper and shorting out the system.
This was the first time I had looked at the fusebox behind the passenger glove box and I was suprised to find that I cannot get at some of the fuses or the spares due to them being blocked by the two large cable bundles (to the left of the picture below).
Are these cable runs normal and if so how do you get the fuses hidden behind them out - my interior mirror isn't dipping and I need to check fuse 69 which is really inacessible.
Post #242835 Sat Nov 14 2009 9:14pm
MAW
Normal and a complete PITA Censored
Post #242838 Sat Nov 14 2009 10:05pm
Endjin
Scotland
Don't even attempt to replace the Front Fogs Fuse! (or many of the others for that matter) Unless you have hands the size of a small baby or African pigmy Mr. Green I had exactly the same problem and after lacerating the back of my hands and dropping the fuse replacement tool inside the bl Censored dy dash assembly whilst trying to access the spares Evil or Very Mad Rolling Eyes I gave up and got my dealer to do it! Much less hassle & definately less painful Embarassed Whistle 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #242858 Sun Nov 15 2009 11:16am
MAW
I lost the spare fuses getting them out IIRC - better off buying spares from Halfrauds and keeping them in the glove box - fitting them is a right PITA Laughing
Post #242859 Sun Nov 15 2009 11:20am
PJPR01
United States 2013 Range Rover Sport 4.4 V8 HSE Orkney Grey
The easiest way to get to the fuses is a pair of long needle nosed pliers...gently grab the fuse and pull as straight back as you can, the fuses come out very easily. You can also use them to put the fuses back, line it up and gently push in.
Highly recommend keeping a couple of each Amp fuse in th glove box, as spares... PJPR
2017 FFRR TD6
Former LR: 2013 RRS, 2006 RRS
Post #242865 Sun Nov 15 2009 4:44pm
MAW
IIRC the red plastic 'tool' centre top of your pic is for removing and replacing the fuses Laughing
Post #242866 Sun Nov 15 2009 5:38pm
PJPR01
that is true, but I find it's also difficult to use in tight spots...so the pliers give you quite a bit of added reach and keep your knuckles from getting rapped in there...give it a shot. PJPR
2017 FFRR TD6
Post #242876 Sun Nov 15 2009 7:39pm
MAW
Oh i agree - just thought there will be some that didn't know Thumbs Up
Post #242884 Sun Nov 15 2009 10:24pm
PJPR01
Thumbs Up Thumbs Up Thumbs Up MAW... PJPR
2017 FFRR TD6
Post #242887 Sun Nov 15 2009 10:49pm
Bob.
Good advice and when the the warranty runs out that's the route I will go but I think I will let the dealer drop fuses in there for now. Anyone had their dipping mirror fail to dip? - may not be the fuse at all.
Post #242964 Mon Nov 16 2009 10:32pm
Bill Portland
hi all
i suspect a blown fuse for the rear screen heater.
how do i get access to the passenger side fusebox? The manual says something about opening the glovebox and squeezing the stanchions. What's the stanchions? Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #547115 Tue Jan 30 2018 1:34pm
Bill Portland
anyone? Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #547139 Tue Jan 30 2018 4:32pm
squeeze the lid supports at the sides
The things that stop the lid dropping to the floor
Post #547144 Tue Jan 30 2018 5:12pm
Bill Portland
Thumbs Up thanks, I'll have another look (when it stops raining). Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #547167 Tue Jan 30 2018 10:12pm
