Home > Technical > EPB Manual Release
bulldog-winston
United Kingdom 2007 Range Rover Sport TDV6 S Java Black
EPB Manual Release
My EPB (Electric Park Brake) seems to be stuck on with the usual neighbor attracting screeching. Tried various up down movements the switch etc and it isn't budging just making noise. I know there is a manual emergency release on the D3, but I can't locate anything about one on the RRS forum.
Have removed the cap in the cup holder and had a good look, nothing, likewise the plate in front of the EPB release and nothing there either.
Can anyone help as I am supposed to be doing 300 miles tomorrow, and wont be going anywhere at this rate !
Post #242104 Thu Nov 05 2009 10:18pm
ELD70
Have you had a look with a torch to spot the release cable under the cup holder flap, it can be pushed back a way out of sight.
Post #242106 Thu Nov 05 2009 10:45pm
CarlW
Scotland 2008 Range Rover Sport TDV8 HSE Java Black
Try http://disco3.co.uk/forum/topic31087.html?highlight=epb+release on the Disco3 site
Hope it works
Post #242107 Thu Nov 05 2009 10:45pm
gianluca
Italy 2006 Range Rover Sport TDV6 HSE Java Black
Re: EPB Manual Release
Hi, the same topic is open in the General session, and I actually asled for the same thing.
Apparently nobody knows the procedure... Yawn My gallery: http://www.rrsport.co.uk/gallery/thumbnails.php?album=994
Post #242108 Thu Nov 05 2009 10:46pm
bulldog-winston
Many thanks guys, will resume my search tomorrow for the cable.
Will let you know how it goes.
Post #242110 Thu Nov 05 2009 11:12pm
bulldog-winston
OK, here's where it is :
Removed the plastic bit between the EPB switch and gear selector. Undid the two screws to remove the EPB switch and hey presto, the manual emergency release was below. Used a bungee cord to pull it and the brake has now disengaged.
Posted a couple of pics to help.
Cheers for all that helped.
Post #242145 Fri Nov 06 2009 12:10pm
MAW
Good info - but what a ridiculous 'fix' Confused What were LR thinking Shocked
Post #242184 Fri Nov 06 2009 3:28pm
