![]() | Home > Maintenance & Modifications > Replacing the steering wheel |
| Simon Sport Member Since: 14 Feb 2009 Location: Somewhere on the road Posts: 10
It's time to replace my worn out and rotting steering wheel. Four screws at rear removed and ........?? What next please!!!!
The new "smooth" OEM steering wheel?
Have gone for the original grained wheel, thought the 'smooth feel' contrasted too much with the other grained areas ie; dash etc
There's a "special" tool required to remove the airbag and switch pack I believe - not sure if a dealer would supply this or not. |
Ok thanks. As it needs a special tool I'll leave it to get replaced at the service in a couple of weeks.
| sid Member Since: 21 Aug 2007 Location: northants Posts: 45
Steering wheel airbag removal tool.
| Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662
£20 |
| BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942
Have a search around, I am sure that Bobby has posted the procedure before, I remember seeing it somewhere Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Once again, the pikeys prove themselves more useful than us
2009 Outstanding Contribution Award - Joint Runner Up 2009 'Tech-Head Of The Year' Award - Runner Up Like it here? Then Donate to RRSPORT!! |
| gianluca Member Since: 18 Mar 2009 Location: Potenza Posts: 136
I had it done by the service.
| 2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382
My worn steering wheel was replaced under warranty... for some reason they also replaced my perfectly good airbag at the same time?! |
