Home > Technical > Rough when starting but only for the first 10 seconds or so?
slcar
From cold start the engine has a really rough vibration but only for about the first ten seconds then it is fine. Can anyone help with this please?
Post #237933 Thu Sep 24 2009 1:43pm
islider
United Kingdom 2006 Range Rover Sport TDV6 SE Java Black
Which engine is it.
The diesels can be quite rough at first on start untill they settle down to idle.
Post #237935 Thu Sep 24 2009 2:07pm
slcar
It is the TDV6 so if its common im not concerned just didnt want it to develop into something serious. I have just added a fuel treatment to the tank so see if it eases up any over the next few days!
Post #237937 Thu Sep 24 2009 2:09pm
islider
Keep an eye on it, but if it is as short lived as you describe, it's nohing to worry about.
If this is an issue, someone on here should pipe up and explain soon. Thumbs Up
Post #237938 Thu Sep 24 2009 2:15pm
slcar
Thank you for your response.
Stuart.
Post #237942 Thu Sep 24 2009 2:28pm
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Some use 2 stroke oil in their fuel tank, if you do a search you'll find it discussed at length.
Post #238014 Thu Sep 24 2009 11:42pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
I have same noise on mine and it was the same on the one before so normal me thinks!!
Post #238355 Mon Sep 28 2009 3:38pm
slcar
Tried the fuel additive and it hasnt made any difference so Im gonna give the 2 stroke oil a go and see if that helps. Does anybody know exactly which oil is recommended please?
Post #238651 Thu Oct 01 2009 11:28am
Forum supporter, Opie Oils should be able to help out with this one Thumbs Up
Post #238652 Thu Oct 01 2009 11:44am
slcar
Thanks Shmoogle..
Post #238657 Thu Oct 01 2009 11:54am
2nd Rower
There are some threads on this site, but I believe it all originated on this thread over on freel2:
http://www.freel2.com/forum/topic878.html
Personally - I've not done it myself.
Post #238661 Thu Oct 01 2009 12:09pm
