![]() | Home > Technical > Funny code |
| will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377
Could be the next service indicator |
| Killerbob Member Since: 27 Sep 2008 Location: St. Gallen Posts: 145
ahhh, I made a mistake:
As others have said, sounds like you have 2900 miles to go until the next service. |
I assume that would be in KMs, as that is what I have set in the settings?
| Alias Member Since: 18 Aug 2009 Location: Zürich Posts: 194
But if it is a message for the service you will see it all the time. How long do you have your TDV8?
Sorry KB, yes kms if that's what you're set to
2009 Outstanding Contribution Award - Joint Runner Up 2009 'Tech-Head Of The Year' Award - Runner Up Like it here? Then Donate to RRSPORT!! |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104
See if the number changes, there is a code you can pull IIRC by holding the odometer reset button before turning the ign key, cannot recall format but seem to think it looked like a registered date or similar.... |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
Service Interval Indicator (SII) The service interval indicator is displayed in the information display. This provides information to the driver warning of an impending service requirement. The service interval is displayed for 3 seconds when the ignition is switched on providing the service interval threshold has been reached. The service interval is reset by the dealer using an approved Land Rover diagnostic system or a manual reset procedure and, once set, counts down the mileage and time in days to the next service. The service interval varies depending on market and vehicle engine fitment. In some Eastern European countries, South American countries, Middle East and African countries and some Asia Pacific countries the SII is disabled. Two levels of service warning are provided; remaining distance and periodic inspection. Remaining Distance The remaining distance is calculated by the instrument cluster by using the current odometer value and the last service reset odometer value. The instrument cluster uses these two values to calculate the distance remaining to the next service. The remaining distance value is used to display the oil service requirement. The mileage is displayed to the nearest 50 Km or 25 miles depending on the market configuration of the vehicle. If the service interval passes zero without being reset, the instrument pack will continue counting down and the remaining distance display will show a negative (-) value. The trigger point for displaying the remaining distance is 600 miles (1000 km) or 30 days or less depending on the market configuration of the vehicle and is contained within the Car Configuration File (CCF). Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Tried this on my MY09 this am and it is different now the old RRS acted as above but now it pulls up a different menu |
| All times are GMT |
