![]() | Home > General > will disco roof rails fit a MY 2010 RRS ? |
RRS is a fair bit wider than D2 - my FFRR crossbars wouldn't fit when I tried them at the local dealer before buying the my 1st RRS. The other problem was that the rail fitting on the cross bar was different.
Just what I would suggest.... I doubt they will fit, the body panelling is virtually all different. |
| wo ping Member Since: 13 Feb 2008 Location: east lothian Posts: 30
I've got the cross bars from a previous RRS so they should work.... it's the actual rails I was wondering about. |
The D3 cross bars do not fit the RRS on the pre facelift models. 2005 Zambezi TDV6 - Gone but not forgotten
| PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355
The feet themselves are identical and fit into the rails on both the RRS and LR3, however the LR3 cross bars are not as wide as the RRS, so you'll come up about 2 inches short. I have modified for a friend a set of extra RRS cross bars and shaved off 2 inches to make them fit onto their LR3, so if you could find just the bars themselves from an RRS you could use the same feet. The construction of the bar is uniform from end to end, you could even have someone manufacture them if you could not buy them separately. PJPR 2017 FFRR TD6 Former LR: 2013 RRS, 2006 RRS |
sorry, I'm not being clear. - my fault.
The ones on the RRS are longer than those on the d3 so the answer is unfortunately not. 2005 Zambezi TDV6 - Gone but not forgotten
